Front end squeek 97 accord
been fighting a nasty squeek for a while now..
it useally happens after i jack the front end up for an oil change. after i let the car back down it will squeek on compression and rebound when the suspension is moved slightly. in the past the squeek would last a couple weeks then go away.. now it has been about 1,000 miles since the change and it is still squeeking. i have tried to spray silicone lube at all the rubber joints and still nothing. could it be the struts?
ideas?
ideas?
Sounds like the strut bushings are getting worn, or the tower-nuts may be loose. If the rubber in the strut assembles is over 7-8 years old, it's getting hard and worn. Wrenchy
