which bearings to use with b20vtec?
Old Dec 7, 2006 | 01:09 PM
xQB21x's Avatar
Default which bearings to use with b20vtec?
main and rod bearings - for now i have only two options - oem honda bearings and acl. which one is better? or maybe you'll recommend some other bearings? i also read that some pepole use b16 oem bearings in such setup. Is it right?
Old Dec 7, 2006 | 05:31 PM
Adi Radoncic's Avatar
On Fire!
Default Re: which bearings to use with b20vtec? (xQB21x)
You either want gsr, rsx type s, or acl bearings.. Bearings are only as good as your clearances are..
Old Dec 7, 2006 | 06:26 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xQB21x &raquo;</TD></TR><TR><TD CLASS="quote">main and rod bearings - for now i have only two options - oem honda bearings and acl. which one is better? or maybe you'll recommend some other bearings? i also read that some pepole use b16 oem bearings in such setup. Is it right?</TD></TR></TABLE>
B16/LS bearings are the same size.. the only difference is the oil hole in the LS rod bearings which allows oil to spray from the rod and to the cylinders.
I personally use B16 clevites.
Old Dec 7, 2006 | 07:35 PM
smileycvc's Avatar
Default Re: which bearings to use with b20vtec? (LSVTEC 91 Civic)
umm Im not sure what the first guy is taking about?? The b20 and LS are the same so just go with oem Honda LS bearings. That is what I have in my B20 and they havent had a problem. So far I put down about 220 whp and I rev to 8500 all day with no bearing issues.
Old Dec 7, 2006 | 07:56 PM
NA JDM GSR's Avatar
oem
Old Dec 13, 2006 | 04:07 PM
xQB21x's Avatar
so you say that b16 or ls bearings could be used but i shouls use ls ones cause they have a hole through which the oil is sprayed, right? i also read that some people use k20 brearings, could they be used?
Old Dec 13, 2006 | 05:04 PM
NA JDM GSR's Avatar
Default Re: (xQB21x)
gsr bearings these are narrower than b16 and ls bearings and consume less oil
Old Dec 13, 2006 | 06:53 PM
JDM DERF's Avatar
if money isnt an issue, use oem. but if it is, use acl
Old Dec 13, 2006 | 06:58 PM
Banned
Default Re: (NA JDM GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA JDM GSR &raquo;</TD></TR><TR><TD CLASS="quote">gsr bearings these are narrower than b16 and ls bearings and consume less oil</TD></TR></TABLE>
Jdm_Ej8_Sedan
Jan 29, 2014 05:34 AM
88Snatch
Dec 23, 2008 07:22 PM
haysr
12
Jul 31, 2005 09:39 AM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
