How much internal work needed on D16Z6 for 250 whp? -searched-
Old Dec 7, 2006 | 12:04 PM
WhiteOnRice's Avatar
Default How much internal work needed on D16Z6 for 250 whp? -searched-
I know this type of question has probably been asked two thousand times but search doesn't work for me...
Okay, I have a 92 hatch (shell) and it's main purpose is for the track, it's not a DD. I figured D16 turbo would be best because it'll be lighter than a B swap and don't have the cash for a B turbo anyways. I want to push about 250 whp.
I will have about $3000 for the engine, turbo (ebay special probably), Hondata/tune. Is the D16Z6 my best option? I need an engine that doesn't need much internal work. How about D15b? Thanks.
Inspiration... http://videos.streetfire.net/c...d.htm
Old Dec 7, 2006 | 12:39 PM
chippy's Avatar
Default Re: How much internal work needed on D16Z6 for 250 whp? -searched- (fizix_skate)
tunertoys rods $220
Vitaras rods $135
ARP headstuds $100
Hone and hot tank $free-100
that should be good too 300 .. vitaras have been able to hit the 400 mark.
Old Dec 7, 2006 | 02:04 PM
LilCivic04's Avatar
Default Re: How much internal work needed on D16Z6 for 250 whp? -searched- (chippy)
a stock z6 can do 250 easily on stock motor reliably. all you need to do is have quality turbo parts and a good tune. no need to spend on rods and pistons if you are only looking for 250hp
Old Dec 7, 2006 | 02:17 PM
chippy's Avatar
Default Re: How much internal work needed on D16Z6 for 250 whp? -searched- (LilCivic04)
that's 250whp not 250 to the crank. i highly doubt the rods can handle that nor the ringlands.
Old Dec 7, 2006 | 02:38 PM
stockb18c's Avatar
your rods can handle 250whp just get a good *** tune and be set
Old Dec 7, 2006 | 02:45 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chippy &raquo;</TD></TR><TR><TD CLASS="quote">that's 250whp not 250 to the crank. i highly doubt the rods can handle that nor the ringlands.</TD></TR></TABLE>
There was someone recently that made like 400whp on those rods. Tuning is what matters most.
Old Dec 7, 2006 | 02:55 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: How much internal work needed on D16Z6 for 250 whp? -searched- (RyanEJ8)
i've seen over 250whp on those stock rods many times
Old Dec 7, 2006 | 04:04 PM
CRXDrew's Avatar
Save the money and keep the motor stock and get a non-ebay special turbo.
Old Dec 7, 2006 | 04:05 PM
SOHC_MShue's Avatar
dont talk out your ***.
My stock z6 block is making over 250whp
Old Dec 7, 2006 | 04:20 PM
THEDirtyDseriesWOOT's Avatar
keep it bone stock ... yah u liked thaat vid huh... if u put vitaras and tuner toy rods .. the list above with a good turbo kit u can make 400 + no prob...
but for 250 id say get a 50trim t3 turbo keep the motor stock.. buy a drag mani off ebay.. some dsm 450s and a resistor box. ebay 100$
and a ebay intercooler .. get a nice charge pipe kit though.. u dont want pipes blowing off all the time .. GET A GOOD TUNE
Old Dec 7, 2006 | 04:57 PM
redzcstandardhatch's Avatar
something different
jeff evans did 380 ish on a stock z6, the car ran 10's and is still alive.
made 420 or something on a boost spike.
Old Dec 7, 2006 | 06:18 PM
chippy's Avatar
Default Re: How much internal work needed on D16Z6 for 250 whp? -searched- (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">dont talk out your ***.
My stock z6 block is making over 250whp</TD></TR></TABLE>
yeah of course it's doable.. but to be safe why would you not be safe with $3000 to spend? A little tempermental are we.
Old Dec 7, 2006 | 06:30 PM
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chippy &raquo;</TD></TR><TR><TD CLASS="quote">yeah of course it's doable.. but to be safe why would you not be safe with $3000 to spend? A little tempermental are we. </TD></TR></TABLE>
Because a well tuned stock block is better than a poorly tuned built one. The rods aren't going to get weaker and ringlands go from detonation not too much hp. Boost the stock block and get it tuned...
Old Dec 7, 2006 | 08:11 PM
HiProfile's Avatar
Default Re: How much internal work needed on D16Z6 for 250 whp? -searched- (nonvtecD)
My stock z6 hit over over 20psi on a t3/t04b when the WG actuator got crushed (accident, thought they were running...and was pissed). Motor is still fine, but I feel I got lucky - and it was up there for 2-3 seconds. The problem with 250whp on stock is that theres no room for error. You'll probably have a 2bar or larger MAP sensor, so you'd want the tuner make sure it gets tuned past a typical boost spike.
$3k would be streching it with hondata and a full kit. I'd almost suggest a kit like a greddy sohc, an fmic, and crome (for ems), then the rest on the above mentioned internals. I have to warn you, you'll need to have $4.5k on hand if you plan on a budget of $3k. **** does happen...
Old Dec 7, 2006 | 08:14 PM
EK k kay's Avatar
Default Re: How much internal work needed on D16Z6 for 250 whp? -searched- (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I have to warn you, you'll need to have $4.5k on hand if you plan on a budget of $3k. **** does happen...</TD></TR></TABLE>
This man speaks the truth. I planned on a $2500 setup, but in the end I spent nearly 4k.
Old Dec 8, 2006 | 11:05 AM
Yeah, I know. But I'll have $3-4000 right away. I'll probably run the turbo w/o the bov before I get hondata/tune. I live in Wisconsin, I wonder where I can get a good tune... damn Wisconsin.
Old Dec 8, 2006 | 11:41 AM
ralph11sec's Avatar
Default Re: (fizix_skate)
250 at the wheels is very very attainable in stock internals with a t3t4. very reliable.
Old Dec 8, 2006 | 03:32 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizix_skate &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I know. But I'll have $3-4000 right away. I'll probably run the turbo w/o the bov before I get hondata/tune. I live in Wisconsin, I wonder where I can get a good tune... damn Wisconsin.</TD></TR></TABLE>
What part of Wisconsin? I'm in Waukesha, setup for CromePro for a good price (needs only chipped stock ecu), along with welding/etc, but I know of other places. I know a guy at Extreme Motorsports down in Racine that does lots of tuning that I trust 110% (personal NA drag car does low 11's). There's also the Whip Factory in Chicago, if you want to drive a bit farther. I believe they are Neptune tuners on top of it.
BTW even a leaking ebay BOV for $25 is better than no BOV - compressor surge is bad, regardless of what people say. The people who say it isn't are also people who'll get lung cancer after 40yrs of smoking, and be completely clueless as to why.
Trevor Chitwood
Oct 1, 2015 11:51 AM
2000Civic
Jun 28, 2012 10:19 AM
The_Honda_Guy
Feb 25, 2009 07:44 PM
1993-eg1
May 15, 2008 03:05 PM
turboex93
Sep 24, 2002 03:46 PM
