what clutch does a sohc zc trans need?
Old May 10, 2002 | 03:55 PM
Ignitecivic's Avatar
Default what clutch does a sohc zc trans need?
i have an the sohc zc engine, but i dont know what clutch fits for it. does any 1.6L civic fit or certain one.
Old May 10, 2002 | 10:47 PM
CRXRageD's Avatar
Default Re: what clutch does a sohc zc trans need? (Ignitecivic)
it really depends on what kind of tranny you are using for one. two, also depends on which flywheel you are using. if you are using an 88 Si tranny you will be working with 21 7/8 shaft as oppose to a 20 7/8 for 89-91 Si. If you are using an 88, 89, or 90-91 flywheel, you will have to get the clutch that will match each one respectfully. The 89 is 200m and the 90-91 is 212mm. There is a significant difference is clamp space. It's really up to you on what to do, if you have an 89 tranny i would just upgrade to a 90-91 flywheel and clutch. I figure is simpler. good luck
tkda
17
Feb 10, 2009 10:39 AM
sykohatch
Aug 16, 2004 08:51 PM
smokinjs420
Oct 18, 2003 08:13 PM
Ronin Panda
15
May 11, 2003 05:05 PM
brusk
Jun 5, 2002 08:53 PM
