mugen suspension gurus, are these n1 or nz coilovers?
Old Dec 7, 2006 | 03:04 AM
an2ny888's Avatar
Default mugen suspension gurus, are these n1 or nz coilovers?
just got this set used, are these nz's or n1's? how many turns can i do on the adjusters? i'm afraid of turning it too much and breaking it. also, can i use 10k and 8k springs on these, or do i have to use stiffer springs to prevent the dampers from burning out? i'd appreciate any feedback you guys can give
Old Dec 7, 2006 | 05:07 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
I don't think it can tell by just looking at it. IIRC, the adjustments on the rear are different. N1 has 5 "clicks" while the NZ has no click, just turn and count how much you turn.
The best way is to contact King.
Old Dec 7, 2006 | 06:17 AM
tartje's Avatar
Default Re: (Wai)
hmm, they look similar to my N1's, but not the same.
my N1's are step free on the front and 5 step on the back. you will know when you've got to the limit of the step free, because it stops
Old Dec 7, 2006 | 07:11 AM
Todd00's Avatar
I said I don't want a title!
Default Re: (tartje)
Yes, both sets of my NZ's don't have a click. You gotta count turns when adjusting.
Externally the N1 and NZ look very, very similar.
Old Dec 7, 2006 | 07:51 AM
an2ny888's Avatar
Default Re: (Todd00)
what spring rates do you guys use? actually i have two sets of rear dampers, i'm assuming the one with the 5 step adj is the n1, while the stepless adj is the nz. also i measured both shaft diameters, the nz appears to be bigger by 2mm
Old Dec 7, 2006 | 08:37 AM
tartje's Avatar
Default Re: (an2ny888)
i have 16k front 14k rear
although those blue ones look like spoon springs??
Old Dec 7, 2006 | 09:51 AM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">i have 16k front 14k rear
although those blue ones look like spoon springs??</TD></TR></TABLE>
actually I think they're Swifts
Old Dec 7, 2006 | 09:52 AM
. a d a m's Avatar
They're swift.
Old Dec 7, 2006 | 10:34 AM
tartje's Avatar
Default Re: (. a d a m)
i stand corrected, thanks guys
Old Dec 7, 2006 | 01:21 PM
Ausmith's Avatar
Default Re: mugen suspension gurus, are these n1 or nz coilovers? (an2ny888)
Are there any stickers with part numbers on them?
The latest generation of NZ and N1 shared all the same components except for internal valving there for it is going to be difficult to tell just by looking at them. I suggest sending them to someone with a shock dyno. That will tell you two things:
1) Which set they are
2) If you need to rebuild them
Clayton @ King
Ausmith's Avatar
There should be 7 ~ 7.5 full turns of adjustment on both shocks.
Old Dec 7, 2006 | 04:08 PM
an2ny888's Avatar
Default Re: mugen suspension gurus, are these n1 or nz coilovers? (Ausmith)
tnx for the info are there any minimum spring rates i should run with these? i remember reading that you might burn them out if you use too soft a spring rate
Old Dec 7, 2006 | 04:22 PM
an2ny888's Avatar
one shock has C/F R469 on it while the other one has GT1/GC1 GR056
Old Dec 8, 2006 | 10:20 AM
Ausmith's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">one shock has C/F R469 on it while the other one has GT1/GC1 GR056 </TD></TR></TABLE>
C/F = N1 Rear Damper w/ high damper rates. I wouldn't run less than 600lbs/in springs on this shock. Upper end would be 1400 lbs/in.
GT1 = NZ Rear Damper. You can run as low as 300 lbs/in on these dampers. Upper end would be 1000 lbs/in.
Old Dec 8, 2006 | 10:43 AM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith &raquo;</TD></TR><TR><TD CLASS="quote">
GT1 = NZ Rear Damper. You can run as low as 300 lbs/in on these dampers. Upper end would be 1000 lbs/in.</TD></TR></TABLE>
Could you pRease provide the suggested front rate ranges too?
Old Dec 8, 2006 | 11:41 AM
Todd00's Avatar
Clayton @ King</TD></TR></TABLE>
Can Mugen rebuild them to true double-adjustables (separate *****)?
Old Dec 8, 2006 | 01:08 PM
Ausmith's Avatar
Default Re: mugen suspension gurus, are these n1 or nz coilovers? (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">
Can Mugen rebuild them to true double-adjustables (separate *****)?</TD></TR></TABLE>
No.
Old Dec 8, 2006 | 04:11 PM
an2ny888's Avatar
like ra said, front spring rate suggestions prease
George Knighton
Aug 27, 2006 10:12 PM
bigfatchien
Jul 5, 2004 06:06 PM
IGGY
Jan 5, 2002 05:35 PM
