Suspension & Brakes Theory, alignment, spring rates....
Adjust caster through radius arm??
Old Dec 6, 2006 | 08:50 PM
integ3's Avatar
Default Adjust caster through radius arm??
On my last alignment the front left wheel measured a -0.3 caster with a specified range of 0.5 to 2.5 degrees. And the front right side was at 1.3 degrees. So I need to adjust my left side +1.6 degrees to match the right side.
I looked under my car, and on the drivers side the crossmember was hit and bent. Getting a new crossmember wont' help because where it mounts to the unibody it's a little bit tweaked...so i'm kinda suck with that messud up crossmember. But I would still like to fix my caster.
Is there a way to adjust my caster through the radius arm?? I see that the radius arm goes through the crossmember and some kind of bushing. Could I put some washers on one side of the radius arm where it mounts to the crossmember? Is there some kind of different radius arm that I could put on thats shorter or longer? Or is there some kind of caster kit out there for my '92 teg.
Thanks
Old Dec 6, 2006 | 09:00 PM
importdude2000's Avatar
use 86-89 accord rods redrilled the holes
im doing it as we speak
Old Dec 7, 2006 | 04:47 AM
integ3's Avatar
Cool let me know how it works out. Are you re-drilling them because they dont fit? Or are you doing that to get some positive caster? Any details would be great.
Thanks
Old Dec 7, 2006 | 07:37 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (integ3)
Just take the radius rod to a machine shop & have them machine the threads a couple inches further up the arm. Then use double locking nuts (like on top of a Koni shock) to adjust the spot that the bushings & washers press up against. I have the same problem on my CRX & my mechanic explained this would be the simplest & most effective way to adjust caster...
Your idea of simply adding washers between the bushings & the radius arm will only work if your trying to reduce caster (push the LCA towards the rear of the car).
1990IntegraLS
Suspension & Brakes
15
Jan 24, 2016 06:12 PM
Nicefeet
Sep 24, 2011 04:31 PM
alexdc03
Apr 26, 2011 07:36 AM
LagunaSecaEG
Aug 20, 2006 06:51 AM
