honda b20b with p8r head
Old Dec 6, 2006 | 07:53 PM
euro_r_wagon's Avatar
Default honda b20b with p8r head
hi all im currently in the process of rebuilding a motor below is what im doing and below that is some questions please feel free to answer them
purchased a complete b20b with p8r head from a local wrecker out of jdm smx
its factory 150hp with sh*t cams and a whopping great (joke) 54mm throttle body
im stripping it down and getting bottom end completly balanced and new piston rings
new oem head gasket
now the head is getting a 35 thou skim and im putting in a set of reground cams(out of jdm b20b from orthia) which have 10 deg more duration and 15 thou more lift
im putting on adj cam gears and a type r (62mm) throttle body and it will have type r (96 spec) headers and full exhaust
i have an apexi super afc to play with it
ok now is there anything else i should do/look out for and what hp do you think i will gain from doing this
cheers matt
Modified by euro_r_wagon at 9:31 PM 12/6/2006
Old Dec 6, 2006 | 08:09 PM
xDicktonesx's Avatar
Default Re: honda b20b with p8r head (euro_r_wagon)
i woudlnt waste your money balancing and blue printing the bottom end of that thing.
i think make 150whp and 125 wtq
Old Dec 6, 2006 | 08:32 PM
im not blue printing it and have been told balancing will be good for it and i can get it done for a real good price
Old Dec 7, 2006 | 04:24 AM
JCushing's Avatar
that motor will respond well to compression and big cams
and deftones is pretty close with that power estimate id say..
Old Dec 8, 2006 | 12:03 AM
anyone???
Old Dec 8, 2006 | 04:42 AM
JCushing's Avatar
Default Re: honda b20b with p8r head (JCushing)
i dont count?
what else are you looking for
Old Dec 8, 2006 | 02:05 PM
anything ive forgotten or maybe some one has skimd the head more and know i can go more and anything like that
Old Dec 9, 2006 | 09:16 AM
JCushing's Avatar
Default Re: (euro_r_wagon)
how much you can mill depends on the piston. im using RS machines 84.5mm ITR copies and my head was milled about .026 and i think it can go a good amount more. on stock pistons you should be able to mill it alot.
Old Dec 9, 2006 | 11:18 AM
was hoping to go about 60 thou (40 off block and 20 off head) that will give some good compression - oh and anyone know how to check piston to valve clearance before you pull apart the motor??
Old Dec 12, 2006 | 08:30 AM
cafcwest's Avatar
Find a set of B20Z pistons?! All things equal, IIRC its about .6 diff in compression right there.
Old Dec 12, 2006 | 07:17 PM
no such thing in this side of the world as a b20z - we only have b20b - b20z is a honda america only motor
Old Dec 13, 2006 | 03:14 AM
JCushing's Avatar
yeah but the newer b20's still came with the phk pistons wich are 9.6:1 compared to the 8.8:1 p3f pistons
hows that
dc2much
Jan 30, 2008 03:56 PM
foreverwefall
May 22, 2007 12:44 PM
manson
Sep 22, 2002 06:29 PM
