ZC problem
Does anyone know any good info on doing timing belts on ZCs? Ive searched and searched every link I click on tells me to do something different, I've adjusted the timing on this ZC like 10 times and still its not acting right, only Codes I have are IAT and coolant temp sensors. It starts up idle is a little high but not too bad but when i tap the throttle rpms just drop like fuel cut off or something. Any suggestions?
do you need info on how to do a timing belt or a timing adjustment?
check out the zc resource
do a search for timing, there are a ton of threads on how to adjust timing and adjust timing belts.
