Having trouble removing driver side axle
Old Dec 6, 2006 | 06:37 PM
christsbane's Avatar
Default Having trouble removing driver side axle
I am having trouble removing the lca from the balljoint, i dont have access to a flat-handled ratchet to jack it up and wedge in between the two pieces, ive been hammering forever with a 2-3 pound sledge but making no progress, and i don't have access to a balljoint puller or whatever that tool is called.
I am using this thread to help me https://honda-tech.com/zerothread?id=382416 but i cant see any of the pictures, I am using a chiltons and a haynes also.
Can someone please tell me exactly where i need to be hammering, I have tried hammering where the damper fork bolts to the lca and hammering on the two stubs where the balljoint puller's arms are supposed to push against, have tried with the rotor jacked up at different heights too.
Running out of ideas and time, i have to be at work friday morning and work through the weekend, and I start school Monday.
Thanks in advance.
Old Dec 6, 2006 | 06:46 PM
PrinceAli132's Avatar
Default Re: Having trouble removing driver side axle (christsbane)
https://honda-tech.com/zero...age=1
There is also a little vid to watch, but its real simple and works like a charm.
Edit - didn't realize you said you don't have the right jack. Sorry
Ali
Old Dec 6, 2006 | 07:40 PM
Default Re: Having trouble removing driver side axle (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zero...age=1
Ali</TD></TR></TABLE>
Well its not that i dont have the right jack, I don't have the right type of ratchet to wedge in there, only flat handled ratchet i have is a 1/4 and thats way too small
Old Dec 6, 2006 | 07:45 PM
reading &gt; me
So you don't have anything around the garage, tool box or house to use as a substitute. Pull some MacGyver ****.
Ali
Old Dec 6, 2006 | 07:54 PM
Lan's Avatar
Lan
Hit the side of the lower control arm with a sledge. HARD.
Old Dec 6, 2006 | 08:11 PM
Default Re: Having trouble removing driver side axle (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">Hit the side of the lower control arm with a sledge. HARD.</TD></TR></TABLE>
Did for 20 mins straight, my ears are still ringing, maybe i'm hitting the wrong spot?
Old Dec 6, 2006 | 08:17 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Do you have one of those forks to split a balljoint?
Use that on the upper control-arm if you can't get the LCA off,
You can get the axle out through there also.
or Did this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christsbane &raquo;</TD></TR><TR><TD CLASS="quote">i dont have access to a flat-handled ratchet to jack it up and wedge in between the two pieces, </TD></TR></TABLE>
But if you can get your hands on one of them, you can separate the UCA with it.
Old Dec 7, 2006 | 07:10 AM
Default Re: Having trouble removing driver side axle (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">Do you have one of those forks to split a balljoint?
or Did this
But if you can get your hands on one of them, you can separate the UCA with it.</TD></TR></TABLE>
yes i have one of those, where exactly do i use it on the uca?
Old Dec 7, 2006 | 09:09 AM
iBrandon's Avatar
If you have an air compressor, use an air hammer with a flat face hammer fitting and hammer around the lower control arm...not the ball joint itself, but around it....it will vibrate loose and pop out in seconds! works like a charm! Done this to all the cars i worked on!
Old Dec 7, 2006 | 09:47 AM
gsrclan's Avatar
Default Re: Having trouble removing driver side axle (iBrandon)
I read some where that a big pry bar works as well, just pray at the spot where you would jam the rachet handle.
Old Dec 7, 2006 | 09:50 AM
Hype-R Stalker
Just put it between the boot and cast part going to it, and hit away.
Old Dec 7, 2006 | 11:58 AM
adman's Avatar
ok well i got the balljoint and lca seperated, now I can't get the axle ou of the tranny, I've tried prying with a parybar and a couple screwdrivers, already broke one screwdriver
any pointers yall could give me?
Old Dec 7, 2006 | 12:29 PM
importdude2000's Avatar
pry. turn/wiggle axle and pull
Old Dec 7, 2006 | 02:25 PM
adman's Avatar
I have never had this much trouble working on a car, now I can't get the axle in, it stops going into the transmission with about an inch left, this is pissin me off
Old Dec 7, 2006 | 03:02 PM
sPaRk'iT's Avatar
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">pry. turn/wiggle axle and pull
pry turn/wiggle axle and push to put it back in
Old Dec 7, 2006 | 03:03 PM
Loi-Tech's Avatar
Default Re: (adman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk’iT &raquo;</TD></TR><TR><TD CLASS="quote">
pry turn/wiggle axle and push to put it back in</TD></TR></TABLE>
what i do is hold the axle straight and hit the other end with a hammer and it should pop in.
Old Dec 7, 2006 | 03:37 PM
qazaq's Avatar
i dont see a need removing upper balljoint.
-the way i done it.
-disconnect lower balljoint (i used crowbar )
-move all assembly to the side where the steering connected to it
while moving it push on the axle from the outer end and it will slide out easy
-take off shock fork, leave the shock alone
-pop the alxe from transmission
-take out the axle
-install a new one
-reassemble everything back in place
-done
takes about 20-30 mins each side
Old Dec 7, 2006 | 04:59 PM
HGZ's Avatar
HGZ
Default Re: (adman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adman &raquo;</TD></TR><TR><TD CLASS="quote">I have never had this much trouble working on a car, now I can't get the axle in, it stops going into the transmission with about an inch left, this is pissin me off</TD></TR></TABLE>
jam that thing in there! i think the reason youre having trouble is that loose ring at the end of the spindle.. it might be sticking out too much..
what i did was take this ring off, bend it closed a just a *tiny* bit more, then put it back on. then the axle went in easier..
don't squeeze the ring closed too much though! it needs to stick out some to keep the axle from popping out easy.
Old Dec 7, 2006 | 06:38 PM
Hype-R Stalker
Default Re: Having trouble removing driver side axle (qazaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qazaq &raquo;</TD></TR><TR><TD CLASS="quote">i dont see a need removing upper balljoint.</TD></TR></TABLE>
The reason he made the thread, was because he couldn't separate the LCA.
Old Dec 7, 2006 | 08:32 PM
Finally got that bitch in there, to get in i just whacked the end with a rubber mallet and it went in no prob, i was reluctant at first but said expletive it, if something breaks I'll go bitch out autozone till they hook me up with a new one.
but i tightened up the fork to the lca and tightened up the hub nut but forgot to stick the balljoint through the LCA, ended up ripping the balljoint boot wide open, probally gonna replace that next week
Fiercesomest
May 2, 2016 09:55 AM
explictness
Dec 26, 2005 12:28 PM
guz
Sep 11, 2005 07:25 PM
tnord
Aug 19, 2005 08:55 AM
GSpeedR
Jul 1, 2002 06:15 AM
