advice from experienced biulder's needed......
Old Dec 6, 2006 | 04:26 PM
Manny86's Avatar
Default advice from experienced biulder's needed......
My mission is to build a single vtec before my kid make's his way out to the world in april. The build im doing is a d16z6 i know it's a single cam but it's all i could afford rite now. I want to boost it i just dont know much about engine building to do it myself . if anyone does not mind giving some advice i would be glad.
Old Dec 6, 2006 | 05:01 PM
STREETWERKZ's Avatar
Default Re: advice from experienced biulder's needed...... (Manny86)
My best advice is to use that little red <U><FONT COLOR="red">Search</FONT></U> button in the upper right hand corner of your screen.
The second best advice is to save more money. if you think you have enough for your build..... TRIPLE IT!
good luck. turbos can be your best friend, or worst enemy.
Old Dec 7, 2006 | 04:37 AM
Autoworks's Avatar
Default Re: advice from experienced biulder's needed...... (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote"> turbos can be your best friend, or worst enemy. </TD></TR></TABLE>
TRUE...well actually TUNING can be your best friend or worst enemy
You don't have to "build" your motor just to turbo it. What kind of power do you want to make? If it's something "mild" then you can simply turbo the healthy motor, tune and be done for th emost part. Like stated earlier, if you think you have just the right amount of $$ to do it, then you may want to save up a bit more for the unexpected"little" things.
If you want an EF specific bolt on turbo kit, shoot me a PM.
Old Dec 7, 2006 | 07:17 AM
JandMmotorsports's Avatar
sleeve the motor, decent piston rods you should have a stong build follow the clearances the the manufacturers give you.
Old Dec 7, 2006 | 09:10 AM
Autoworks's Avatar
Default Re: advice from experienced biulder's needed...... (JandMmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JandMmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">sleeve the motor, decent piston rods you should have a stong build follow the clearances the the manufacturers give you.</TD></TR></TABLE>
Don't waste your $$ sleeving the D, it is un needed for a good setup. Many make great power on stock sleeves.
Old Dec 7, 2006 | 09:46 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: advice from experienced biulder's needed...... (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
X2 agreed.
Spend money on the turbo set-up. There are several examples in the forced induction forum who make over 250 whp with zero problems on stock sleeves. I would search there first for similar builds.
ChrisUlrich
Feb 4, 2007 06:56 AM
jdmbb6-t
Jun 23, 2006 02:44 PM
DarkDragon
Audio / Security / Video
Nov 15, 2005 05:19 AM
chinoty
Welding / Fabrication
Jul 16, 2005 10:34 AM
jdmtuner_00
Jan 13, 2005 04:23 PM
