lexan cutting
Old Dec 6, 2006 | 04:02 PM
denske's Avatar
Default lexan cutting
whats the best tool for cutting lexan? what kind of blades do you use? i wanna use a jigsaw so i have better control over it. thanks in advance for any advice.
Old Dec 6, 2006 | 05:00 PM
blueoval557's Avatar
Default Re: lexan cutting (denske)
Use a jigsaw with a fine toothed blade in it. Be sure to mask off the lexan where the base plate of the saw will be riding though...or youll have TONS fo scratches! Good luck!
Old Dec 6, 2006 | 10:05 PM
Top Ramen's Avatar
Default Re: lexan cutting (blueoval557)
Go to a place that sells lexan to sign companies and they will have blades made for cutting it. If I recall correctly, they are fine-toothed with little or no offset.
Best of luck in your project.
Old Dec 6, 2006 | 10:49 PM
PPLH8R's Avatar
If you want it to be perfect and I mean perfect you want to use a laminate trimmer. The same thing they use to finish counter tops. You make a pattern out of wood then you lay the lexan on top of the wood and use a flush trim bit to trace the wood pattern. Not only will it come out perfect it will only take you a matter of seconds to reproduce another window that is exactly the same. If you take your time they will look like this.
Good luck
Old Dec 8, 2006 | 09:47 AM
sharkytm's Avatar
Fine tooth blade in a jigsaw, and tape both sides of the cut. Don't force the blade forward, let it do its work, or you'll melt the plastic.
attica
Paint and Body
18
Aug 29, 2009 03:03 PM
idriveadelsol7
Apr 16, 2005 01:16 PM
Flamenco-T
May 4, 2003 07:02 AM
LuderCriS
Aug 27, 2002 07:29 PM
00b18b
Oct 5, 2001 05:13 PM
