gsr vs. type r
Old Dec 6, 2006 | 02:43 PM
lqd44's Avatar
Default gsr vs. type r
when i read reviews on the integra, and they mention the trim levels, i always see them talk about the gsr and then when they mention the type r, they say it is a modified version of the gsr.
so im wondering, does the type r body and gsr body have any dramatic differences, in terms of suspension parts and handling?
Old Dec 6, 2006 | 02:45 PM
Wendys or Bust's Avatar
yes, there are several differences. The type R uses the Base model chasis (non sunroof) stiffer springs, a b18c5, bigger better brakes, lighter, nicer interior, stiffer chasis. Larger front and rear sway bars.
Old Dec 6, 2006 | 02:49 PM
lqd44's Avatar
Default Re: (Wendys or Bust)
oh, that makes sense, i have been wondering because u realli never hear people swapping gsr parts with type r parts
Old Dec 6, 2006 | 02:50 PM
.brian.'s Avatar
http://www.team-integra.net/se...ID=43
http://www.team-integra.net/se...ID=40
in addition to those two links, read this:
What sets the Type-R apart from any other Integra?
<U>Engine/Drivetrain:</U>
Revised high flow intake
Revised high flow exhaust
Polished and ported heads and ports
Molybdenum coated piston skirts
62mm throttle body
Lightweight valves
Lighter, stronger flywheel
Redline bumped up to 8400 RPM
Limited slip differential
<U>Body/Chassis/Suspension:</U>
Larger brakes (11.1 inch front, 10.2 inch rear)
Revised lighter ABS system
5 lug Hubs
15x6 Alloy wheels
Bridgestone RE-010 tires
New front air dam
Larger rear spoiler
Short throw transmission with shorter gears
Front shock tower bar
Two rear stabilizer bars
- There is really only one rear stabilizer bar. The other bar, which was added for the ITR only, is actually a lower suspension brace - it has no dynamic suspension interaction other than to help prevent chassis flex
Stiffened suspension
Little over a 1/2 inch (15mm) lower ride height
Faux Carbon Fiber instrument panel (Center Console in 2000/2001)
Deep bolstered, race-inspired seats
Subtraction of 147 lbs (No sunroof, A/C, sound deadening material)
Only offered in White until 2000 then Yellow and Black were also offered
No protective side moldings
Old Dec 6, 2006 | 02:51 PM
ejmatzell's Avatar
Default Re: (lqd44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lqd44 &raquo;</TD></TR><TR><TD CLASS="quote">oh, that makes sense, i have been wondering because u realli never hear people swapping gsr parts with type r parts</TD></TR></TABLE>
whaaaaaat? (borat voice) people do it all the time.
Old Dec 6, 2006 | 02:58 PM
PrinceAli132's Avatar
Default Re: gsr vs. type r (lqd44)
http://www.itrca.com/FAQ/general/spottersguide.php
https://honda-tech.com/zerothread?id=857260
https://honda-tech.com/zerothread?id=795299
https://honda-tech.com/zerothread?id=525368
Ali
Old Dec 6, 2006 | 03:34 PM
lqd44's Avatar
Default Re: gsr vs. type r (PrinceAli132)
oh wow, i tried searching for it but i guess i wasnt searching for the right word, sry if i knew there were threads already, i wouldnt have asked, thanks alot for the info guys
MegustaVtec
Jun 11, 2013 06:34 PM
supra360
Dec 13, 2006 05:13 PM
integraracer96
Aug 12, 2004 12:56 PM
Dragger817
Oct 29, 2003 10:46 AM
hatchback
Nov 10, 2002 11:54 PM
