Which way would you go??
Old Dec 6, 2006 | 02:14 PM
rdeezy78's Avatar
Default Which way would you go??
I'm building a gsr block with ls crank and rods. I'm looking for about 400-425 hp, on 93 pump gas. I'm pandering what bore size to go with. I was thinking 83mm at first or 84mm. What I want to know is what is the benefit of that extra mm. Alsowhat compression pistons would you guys go with? Thanks for any insight.
Old Dec 6, 2006 | 02:19 PM
BLKTeg94's Avatar
I've seen 400hp on stock GSR's that have lasted over two years and still going. No need to really sleeve, I'd do a 81.5mm bore with stock sleeves, 9.5-10.0 compresson.
Old Dec 6, 2006 | 03:06 PM
rdeezy78's Avatar
Default Re: (BLKTeg94)
Thanks. I wanted to sleeve though in case I wanted to run high boost. Wasn't sure if there was a great benefit with the larger bore size, or i would just go with 81.5. Since I'm running an ls crank would my compression still be 9.0-1 if I got 9.0-1 pistons? Since the stroke is 2mm bigger.
Old Dec 6, 2006 | 03:07 PM
rdeezy78's Avatar
Default Re: (rdeezy78)
If the compression is different, how would I calculate that?
Old Dec 6, 2006 | 07:43 PM
doood's Avatar
been there done that
Default Re: Which way would you go?? (rdeezy78)
here's what earl (rip earl) has to say about it: http://www.laskeyracing.com/shop/maxbore.htm
Old Dec 6, 2006 | 07:58 PM
turbod da's Avatar
stock bore.
Old Dec 7, 2006 | 03:21 PM
rdeezy78's Avatar
Default Re: Which way would you go?? (that one doood)
Is there really any benefit from stock bore to say 83mm. Hp wise or lower or higher compression?
johnson_racing
48
Jun 1, 2011 10:20 AM
lsturbo*
Aug 19, 2006 04:06 AM
E-spec Tuner
Oct 14, 2003 02:47 PM
HX_Guy
Nov 9, 2001 11:55 AM
HX_Guy
Nov 9, 2001 07:02 AM
