Buddy club cam gears torque ?
Old Dec 6, 2006 | 01:53 PM
skata89's Avatar
Default Buddy club cam gears torque ?
What does the 4 small bolts torque down to? And what does the nut in the middle soppose to torque down to for a jdm itr?
Old Dec 7, 2006 | 02:55 AM
skata89's Avatar
bump
Old Dec 7, 2006 | 03:01 PM
Rocket's Avatar
Default Re: (skata89)
Bump.
Old Dec 7, 2006 | 06:40 PM
Combustion Contraption's Avatar
Default Re: (Don Lackey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Lackey &raquo;</TD></TR><TR><TD CLASS="quote">Bump.</TD></TR></TABLE>
lol
Old Dec 8, 2006 | 09:20 AM
Rocket's Avatar
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
lol</TD></TR></TABLE>
x2
Old Dec 8, 2006 | 09:41 AM
IntegraType-R's Avatar
Get an allen wrench and tighten them until you can't go anymore?? Search..i run these cam gears.. when it goes tight i usually do a full turn on top of the tightness feel, i haven't had any problem with them i'm guessing 12 ft of torque tho.
Old Dec 8, 2006 | 09:46 AM
Rocket's Avatar
Default Re: (IntegraType-R)
Good advice re the "feel" method. There are dangers to using a torque wrench because the "positive" click is often not felt by the novice and this leads to broken fasteners. Also you will need a very small torque wrench (1/4") and those tend to be expensive.
Old Dec 8, 2006 | 11:44 AM
ITRnorway's Avatar
use a allen key an thight until you can feel the bolt float in the threads. now turn 90degrees counter clockwise
OR
call a BC dealer and ask him
Old Dec 8, 2006 | 02:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Lackey &raquo;</TD></TR><TR><TD CLASS="quote">Good advice re the "feel" method. There are dangers to using a torque wrench because the "positive" click is often not felt by the novice and this leads to broken fasteners. Also you will need a very small torque wrench (1/4") and those tend to be expensive.</TD></TR></TABLE>
listen to this man..and what was posted..
over tighten these small bolts, and u reving high..will make u remember not to overtighten things..
Old Dec 9, 2006 | 01:40 PM
skata89's Avatar
So should I just use an allen wrench and do what
ITRnorway said "use a allen key an thight until you can feel the bolt float in the threads. now turn 90degrees counter clockwise.
Old Dec 9, 2006 | 01:47 PM
DonF's Avatar
AS crankshaft Davis told "ring it off and back up half a turn" . Or call Buddy Club, they are suppoed to know.
94draglude
May 21, 2007 04:16 AM
bustdgst
11
Oct 21, 2006 04:32 PM
R91Si
Apr 10, 2006 06:06 AM
drudy
Jan 31, 2005 03:03 PM
hondaguyef
Jan 3, 2005 05:02 AM
