Pulley Eccentric ?
ec·cen·tric /ɪkˈsɛntrɪk, ɛk-/ Pronunciation Key - Show Spelled Pronunciation[ik-sen-trik, ek-] Pronunciation Key - Show IPA Pronunciation
–adjective 1. deviating from the recognized or customary character, practice, etc.; irregular; erratic; peculiar; odd: eccentric conduct; an eccentric person.
2. Geometry. not having the same center; not concentric: used esp. of two circles or spheres at least one of which contains the centers of both.
3. (of an axis, axle, etc.) not situated in the center.
4. Machinery. having the axis or support away from the center: an eccentric wheel.
5. Astronomy. deviating from a circular form, as an elliptic orbit.
–noun 6. a person who has an unusual, peculiar, or odd personality, set of beliefs, or behavior pattern.
7. something that is unusual, peculiar, or odd.
8. Machinery. a device for converting circular motion into rectilinear motion, consisting of a disk fixed somewhat off-center to a revolving shaft, and working freely in a surrounding collar (eccentric strap), to which a rod (eccentric rod) is attached.
now what it does I can't tell you
it just means the hole through the pulley isnt in the center of the pulley.
like if it were on a belt, you could rotate the pulley closer to, or farther away from the belt.
8VEYBEYB
11
Aug 13, 2009 05:44 PM
