smog question?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dylokjai »</TD></TR><TR><TD CLASS="quote">if everything is done right on a obd-1 LS swap to a 93 civic will that pass smog?</TD></TR></TABLE>
i'm sure it should pass
good luck...
good luck...
The engine according to CARB must be the same year or newer and retain all SMOG equipment that came from the factory.
So if the engine is an OBD-1 LS from a 1992 and you are putting it into a 1993 car, it will fail. Be aware of the year engine you are purchasing.
Mario-
Mario-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUNNYz »</TD></TR><TR><TD CLASS="quote">no is not going to pass. because is different engine.
unless u got a BAR sticker on the car.</TD></TR></TABLE>
You don't need the sticker to pass smog. Butyou need to pass smog to get the sticker
No.... you can make it smog exempt, which avoids the smog issue all together, but, you better go out of your way to make that swap look and run great if you want to get it bar'd... keep in mind, that, if your engine swap and wiring looks shitty, you will never get it bar'd....
dingusjt
Dec 24, 2003 02:01 PM
