HELP! I wanna slam my Omni's
Just to let everyone know I already posted this in the suspension forum but nobody has responded, and I need an answer now.
I have a set of Omni Powers on my 95 Accord and I want to lower it about another 2 inches. I am not sure how to lower the coilover. When I put them on and adjusted them I just lowered the sleeve and didn't mess with the actual spring. However it was a bitch trying to turn the sleeve with my hands. Am I able to lower the actual spring or will it mess it up? How can I adjust them better than trying to spin the sleeve with my hands?
damn another 2 inches. How high is it right now? I wasnt aware Omnis were rebound adjustable.
I have no experience with Omni's, but my guess is that you could use a spanner wrench?
If it's something like a Ground Control sleeve, then you'd have to loosen the sleeve with an allen wrench.
ALSO, it might also help cleaning the dirt off the sleeves and/or using wd40.
I have the adjusting tools but I thought it was to lower the actual spring. I am not sure if you are supposed to mess with the spring, thought you just turn the sleeve. It tucks the stock Ex wheels but I have some 16" C8's 205/45/16 on now and there is about a 1 inch gap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 »</TD></TR><TR><TD CLASS="quote">how do i twist the shock body into the mount? I already loosened the bottom lock thing but i am unable to turn the shock body.</TD></TR></TABLE>
hold the middle of the shock. and turn clockwise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge »</TD></TR><TR><TD CLASS="quote">hold the middle of the shock. and turn clockwise. </TD></TR></TABLE>
yep, i twisted the whole shock by hand, it's tough but it's worth it
these coilovers suck! My old ebay ones were easier to adjust and they were like $40. Wish these were easier to do than this ****. I tried to turn it with no luck. the **** hurts your hands And what the hell are the two wrenches for then if you dont use the to adjust it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 »</TD></TR><TR><TD CLASS="quote">might be easier to just remove them and adjust them that way.</TD></TR></TABLE>
that would be alot harder than just twisting them, be a man and use some muscle
they shouldnt be easy to adjust, or else theyll just back off when you drive, dont be a wuss just twist the dam things. if you try to just lower the spring itll be really bouncy. if you need to spray em with some wd40 then twist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 »</TD></TR><TR><TD CLASS="quote">Loosen the lower lock-collar and just twist the bottom until you're satisfied. Relock, and you're done.</TD></TR></TABLE>
the bottom doesn't move, the shock body is what you twist
Finally slammed it!!! Only thing its so low, it drag the damn catalytic converter on the ground when I drive
Might try to do something bout that but looks damn hot!
The shock wouldn't turn. I had to drop the lower control arm to adjust the front. I'll post some pics of it tom. Stay tuned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2coupes »</TD></TR><TR><TD CLASS="quote">
the bottom doesn't move, the shock body is what you twist</TD></TR></TABLE>
The bottom does move, and it's alot easier to turn then the shock body
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 »</TD></TR><TR><TD CLASS="quote">Finally slammed it!!! Only thing its so low, it drag the damn catalytic converter on the ground when I drive
</TD></TR></TABLE> LMFAO lol
haha been there done that, you'll soon find out that its not really worth it once the replacement parts bill comes along. I just replaced my headers, oil pan, oil pan gasket, and whole entire mid pipe and cat shield. It's money i could of used elsewhere on the car. but then again if your ballin go for it
for Omni adjustability
