2005 cbr 600rr battery keeps dying on me
Old Dec 6, 2006 | 10:10 AM
crxma22's Avatar
Default 2005 cbr 600rr battery keeps dying on me
i have a cbr that won't hold a charge. if i jump it the battery usually lasts a week or so... i bought a new battery and that was actually worse than the stock one i had... any ideas?
Old Dec 6, 2006 | 11:12 AM
bad-monkey's Avatar
try the regulator/rectifier
Old Dec 6, 2006 | 11:33 AM
.RJ's Avatar
.RJ
Default Re: 2005 cbr 600rr battery keeps dying on me (crxma22)
Did you charge the new battery before you put it in?
Old Dec 6, 2006 | 12:13 PM
crxma22's Avatar
Default Re: 2005 cbr 600rr battery keeps dying on me (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">try the regulator/rectifier</TD></TR></TABLE>
i'm not too handy when it comes to bikes, so i guess i fit in the noob category... gotta start sometime right? well so is the regulator /rectifier equivalent to a alternator on a car? how should i test it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Did you charge the new battery before you put it in?</TD></TR></TABLE>
your suppose to charge the battery when it's new? ah man maybe that's the problem?? well it started and ran for a few days then went dead.. i'm ready to just off it cuz it's been sitting for about a month.. now when i try to jump it it doesn't even start...
Old Dec 6, 2006 | 12:18 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxma22 &raquo;</TD></TR><TR><TD CLASS="quote">your suppose to charge the battery when it's new?</TD></TR></TABLE>
Yes. You killed it already. Get another one, and a 1 amp charger. It will take ~5 hrs to charge the new battery.
Old Dec 6, 2006 | 12:37 PM
crxma22's Avatar
thanx, i'm going to grab a new battery and tender hopefully that works... those friggin' batteries are expen$ive as fark..... but i do miss riding
Old Dec 6, 2006 | 12:58 PM
.RJ's Avatar
.RJ
I buy my batteries from advance auto... $30, never had a problem.
Old Dec 6, 2006 | 01:10 PM
crxma22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I buy my batteries from advance auto... $30, never had a problem.</TD></TR></TABLE>
good lord!! i spent 135. on the last one i bought... i'll try and swap it if not i'll go with a cheap battery... is advance auto a shop in your area or online?? thanks for the info...
Old Dec 6, 2006 | 03:02 PM
SlowazzGSR's Avatar
Walmart FTW on batteries.
Old Dec 8, 2006 | 06:50 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: 2005 cbr 600rr battery keeps dying on me (SlowazzGSR)
noo...cycle gear batteries for $60 and then buying the warranty and having it replaced for $10 within a year.
Old Dec 8, 2006 | 07:51 PM
Zapko Motorsports's Avatar
Default Re: 2005 cbr 600rr battery keeps dying on me (AzntaggeR)
NOOOOOOOO! Please don't buy a new battery! I see new bikes with new batteries come back to the dealer all the time, and it's because the dealer didn't charge the bat with the top cracked/off. You need to unseal the lid prior to charging especially for the first time. Try this before doing anything else. I don't have time to explain the physics of batt. charging, just give it a shot.
Old Dec 8, 2006 | 08:19 PM
.RJ's Avatar
.RJ
Default Re: 2005 cbr 600rr battery keeps dying on me (Zapko Motorsports)
You dont need to open up the battery to charge it - I never have, and I dont think i'd recommend it - there's acid in there. There is a vent tube on the battery for a reason.
Old Dec 9, 2006 | 11:20 AM
luudog55's Avatar
I had the same problems with my battery not holding a charge so i went out and bought a new battery and put it right in and everything has been ok since. New batteries should be charged right out of the box and ready to go.
Old Dec 9, 2006 | 11:28 AM
Default Re: 2005 cbr 600rr battery keeps dying on me (luudog55)
Wrong... the batteries aren't shipped to the dealers charged... it is their responsibility. And yes, cracking the cap open (how else would you add water if necessary) for the first charge is recommended.
Old Dec 9, 2006 | 11:46 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zapko Motorsports &raquo;</TD></TR><TR><TD CLASS="quote"> And yes, cracking the cap open (how else would you add water if necessary) for the first charge is recommended.</TD></TR></TABLE>
Check the instructions for the battery - many say DO NOT add water.
Again, you dont need to take the caps off to charge it. Thats what the vent is for.
Old Dec 9, 2006 | 12:53 PM
ceas's Avatar
I'm not too familiar with newer stuff - but can't you just push start it?
westcoastEJ1
May 8, 2006 11:16 AM
fanta!
18
Dec 8, 2005 11:52 AM
fanta!
Dec 7, 2005 10:52 AM
RGoose18
May 23, 2005 05:47 AM
DocSean
Honda Motorcycles
Apr 19, 2005 08:14 PM
