Problem with my 98 accord - please help
Old Dec 6, 2006 | 06:47 AM
Nikos's Avatar
Default Problem with my 98 accord - please help
My accord drives but sometimes shuts off while on the road.. I pull over, try to start it... no power to the motor... then after 10-20 seconds it will run for another 2-3 weeks till it does this.. I think it does it more on hot days then cold days, but it has done it in both day and night...
I thought it was the main relay but I was wrong.. because after replacing it, it still does it.. I also replaced the distributor cap with a new one and that didn;t help either... Car has 140K miles, LX 5 speed
thanks for any advice
Old Dec 6, 2006 | 08:29 AM
hondadude's Avatar
Default Re: Problem with my 98 accord - please help (Nikos)
Did you have the ignition switch recall done yet?
Ask your local dealer to run a VIN status inquiry for you.
Old Dec 6, 2006 | 06:43 PM
Stripped Honda's Avatar
99-0104
Default Re: Problem with my 98 accord - please help (hondadude)
sounds like the ignition pigtail .... i would replace it .... the recall expired for this car already so you will have to just buy one yourself they are not too expencive
Old Dec 6, 2006 | 09:53 PM
Nikos's Avatar
Default Re: Problem with my 98 accord - please help (Stripped Honda)
If you could get me the exact part number I need I would be gratefull.
https://www.hondapartsdeals.co...onent=
Old Dec 6, 2006 | 10:16 PM
99-0104
35130-S84-A01, Ignition Switch
this was for a 98 accord LX 2 door 5 speed .... if your car is different then this then the part # might be different
Old Dec 6, 2006 | 10:42 PM
accordinglyevil's Avatar
i might not be the iginition recall. i got both recalled replace at honda and it still does that ish to me. i still haven't figure it out yet on mine.
Old Dec 6, 2006 | 11:15 PM
shadow_ridge's Avatar
Default Re: (accordinglyevil)
main relay? I remember when mine was shot it would stall out on me and not turn on for hours.
it was about 80 sumtheng to replace.
Old Dec 6, 2006 | 11:36 PM
99-0104
Default Re: (shadow_ridge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow_ridge &raquo;</TD></TR><TR><TD CLASS="quote">main relay? I remember when mine was shot it would stall out on me and not turn on for hours.
it was about 80 sumtheng to replace.</TD></TR></TABLE>
he changed it ...
its the ignition switch, ignitor or the ecu ... i cant see it being anything else
Old Dec 7, 2006 | 03:31 AM
Nikos's Avatar
thanks, I am going to change it and let you guys know. Thanks for all the help,
Nikos
Old Dec 7, 2006 | 06:36 AM
Heat's Avatar
Recalls expire? I didn't realize that, there is still an outstanding recall on my '99 LX for something in the fuel injection or something about the throttle, can't remember exactly. I just remember looking at what was being recalled and thinking "if it ain't broke, I don't want them messing with that area of the engine".
But the ignition switch recall, that one I did have done.
Old Dec 7, 2006 | 07:16 AM
DSKlos's Avatar
Default Re: Problem with my 98 accord - please help (Heat)
My car did something similar... except it never turned back on. Does anything else work (headlight alarm, radio, interior lights... ANYTHING), or is everything completely dead? When mine did this I replaced the ECM, which didn't do anything, then I replaced the coil and that fixed it completely...
Since the problem is intermittant, I would guess the ECM, but if they say the ignition switch already has a recall on it, that sounds like the best place to start.
rspears2001
Apr 8, 2011 09:06 AM
bassysingh
Mar 8, 2010 04:21 AM
honda_dude43
Jul 25, 2005 05:43 AM
nmehta211
Jan 2, 2004 06:52 PM
