Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Rough idle after Fujita SRI install
Old Dec 6, 2006 | 05:59 AM
biglos's Avatar
Default Rough idle after Fujita SRI install
I was thinking it was only going to do it when i first installed it, but when driving to work this morning at just about every light it would do it too.....suggestions???
Old Dec 6, 2006 | 06:00 AM
Type X's Avatar
Default Re: Rough idle after Fujita SRI install (biglos)
After you installed it
did you let the car idle for 10-15 minutes giving the ecu time to "adjust" for it?
or did you hop in and go speeding around?
Old Dec 6, 2006 | 06:11 AM
Nohawk's Avatar
Did you recheck your install as well?
Old Dec 6, 2006 | 06:12 AM
biglos's Avatar
Default Re: Rough idle after Fujita SRI install (Type X)
i let it sit for like 5 mins did i mess it up by doing that???
Old Dec 6, 2006 | 06:13 AM
biglos's Avatar
Default Re: Rough idle after Fujita SRI install (Si 4 Life)
i rechecked the install and everything was secure and tight....
Old Dec 6, 2006 | 06:15 AM
WILD_WILL's Avatar
Post pics make sure your vibration mount is def secure and your filter is not hitting anything just keep adjusting until it goes away.
Old Dec 6, 2006 | 06:16 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biglos &raquo;</TD></TR><TR><TD CLASS="quote">i let it sit for like 5 mins did i mess it up by doing that??? </TD></TR></TABLE>
i would disconnect the battery for a good 10-15 min.
Reconnect and let it run for another 10-15 minutes.
Than go for a drive without pushing it.
biglos's Avatar
Default Re: Rough idle after Fujita SRI install (WILD_WILL)
will try and get some pics on lunch its too far to go to parking garage and get them
Old Dec 6, 2006 | 06:17 AM
biglos's Avatar
see this is why i like this site...thx for the help fellas...
Old Dec 6, 2006 | 06:27 AM
WILD_WILL's Avatar
I didnt disconnect my battery i felt there was no need 2 and had no problems with idle but in this case its worth a shot.
Old Dec 6, 2006 | 06:39 AM
MonkeyConQueso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WILD_WILL &raquo;</TD></TR><TR><TD CLASS="quote">I didnt disconnect my battery i felt there was no need 2 and had no problems with idle but in this case its worth a shot.</TD></TR></TABLE>
Old Dec 6, 2006 | 06:47 AM
Nohawk's Avatar
Default Re: Rough idle after Fujita SRI install (MonkeyConQueso)
I guess someone didn't read the instructions.
Old Dec 6, 2006 | 06:57 AM
WILD_WILL's Avatar
I read them but in reality there is no need 2 there is nothing to give a shock off during installation i am a electrician i should know. I guess the main purpose for that is 2 reset the ecu or etc but it ran fine so i guess its not needed.
Old Dec 6, 2006 | 07:02 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WILD_WILL &raquo;</TD></TR><TR><TD CLASS="quote">I read them but in reality there is no need 2 there is nothing to give a shock off during installation i am a electrician i should know. I guess the main purpose for that is 2 reset the ecu or etc but it ran fine so i guess its not needed.</TD></TR></TABLE>
well the reason for the ecu resetting itself is to compensate for "more air" coming int the system.
It might run fine.... BUT .... it could run better.
CEL, rough idle , minimized performance upside....etc etc
Exhibit a =
are you driving to all these places in the same amount of time it takes to install an intake system? no. this cant even come close to comparison, installing a high flow intake adds more air flow that an ecu dosent know what todo IMMEDIATLY, causing a CEL. driving over thousands of miles to all your places, would allow the ecu to learn and therefore no conflicting readings for the ecu.
and remember your old gallant is not as **** as the is300.
taken from our friends @ the Lexus IS forums
http://my.is/forums/archive/in....html
Old Dec 6, 2006 | 07:22 AM
Type X's Avatar
Sends up batsignal to RBF351... for answer and final data on this topic
:flashes light at sky:
Old Dec 6, 2006 | 07:34 AM
biglos's Avatar
Laughing at bat signals LOL...will unplug and try it on lunch break...
Old Dec 6, 2006 | 07:49 AM
rbf351's Avatar
bat signal spotted
best bet is to pull the backup fuse from where ever they keep it in the new Si's, leave it out for about 10-30 seconds. you might lose presets, but it will reset the ECU
LS AzZkIkr
Aug 29, 2009 08:21 AM
95civicSirCoupe
Sep 11, 2006 07:49 AM
big-cat
May 16, 2006 07:03 PM
CaTiRo
Mar 23, 2004 11:25 PM
