Changing the original speaker system in a Honda Cr-x del sol ?
Old Dec 6, 2006 | 04:58 AM
dels's Avatar
Default Changing the original speaker system in a Honda Cr-x del sol ?
What speakers should i buy if i want to change the original speakers ? which speaker dimentions are suited for this car?
Old Dec 6, 2006 | 06:01 AM
carlsberg's Avatar
you'll need 6.5" speakers for the fronts and rears. i know the inifinity reference series (not sure if you have them in the US) fit straight in, be wary as not all 6.5" speakers fit. There is enough room for MDF spacers in the fronts, but the rears are a tight squeeze. Id deffo go for a decent set of components in the front and a set of co-axs in the rear.
Youcan also take the rear brackets out, which might help you, as you can take them along to the nearest audio centere to measure up and see what fits.
Old Dec 6, 2006 | 08:21 AM
EL Vap133's Avatar
Default Re: Changing the original speaker system in a Honda Cr-x del sol ? (dels)
http://www.crutchfield.com/whatfits
Old Dec 7, 2006 | 10:19 AM
dels's Avatar
Default Re: Changing the original speaker system in a Honda Cr-x del sol ? (EL Vap133)
What is a MDF spacer ?
gcupp
Audio / Security / Video
May 15, 2017 03:40 AM
Phil_McKrevice
Dec 1, 2015 08:55 PM
s2000onvolks
10
Feb 1, 2008 08:33 AM
RosebloodSol
Dec 1, 2001 10:37 AM
