HF Axle question
alright i keep it short and simple
I have a HF with a b16a swap done by chris and his crew at hookups now whitfield
Im doing a 96 4x114 conversion on my crx...
question is i have stock knuckles right now on my HF. When i got my swap done at whitfield i dont know what axles they had used all they said was "custom". The actuall axle looks small and the axle hole on the ITR knuckles seem bigger? Are there the same amount of teeth do you think?
anyone who has done a SiR/ITR knuckle swap did you use your stock axles? or do you need aftermarket ones?
how can you have stock hf knuckles and b-series axles?,,he probaby put on dx or si knuckles for you.
Maybe the integra 4x114 knuckles you have use the 36mm axles instead of the standard 32mm..
cb07
Apr 7, 2008 07:15 AM
superbeastcrx
Nov 3, 2004 05:11 PM
