i need your opinion on fuel pump issue
Old Dec 5, 2006 | 09:21 PM
charlee's Avatar
Default i need your opinion on fuel pump issue
OK. i have a ED6 with a d16y8 block and everything else OBD0. i believe that my fuel pump is going bad because every time im low on fuel my car tends to die after coming out of a load. after deaccelerating and coming to a stop. i searched a lot, and all i find is pump how too's and Q's about the fuel pump removal from noobs. things replaced
main relay
fuel filter
checked fuel preasure ( but when it was in a full tank) came out perfect
so im thinking is my fuel pump.
what do you guys thnink?
here is an old pic, just to drw more attention. NVM the spark plug wires. i rplaced then already
any help will be apreciated
EDIT: i also checked the fuel preasure with an almost empy tank, but its hard to diagnose because it only does it when its moving (came out ok)
Old Dec 5, 2006 | 10:14 PM
charlee's Avatar
Default Re: i need your opinion on fuel pump issue (charlee)
bump
Old Dec 6, 2006 | 07:52 AM
charlee's Avatar
anyone?
Old Dec 6, 2006 | 08:18 AM
65stang90crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charlee &raquo;</TD></TR><TR><TD CLASS="quote"> i believe that my fuel pump is going bad because every time im low on fuel my car tends to die after coming out of a load. after decelerating and coming to a stop.
EDIT: i also checked the fuel pressure with an almost empty tank, but its hard to diagnose because it only does it when its moving (came out ok)
</TD></TR></TABLE> My car used to starve really bad before. It was because my boot on the bottom of the fuel pump had came off and it couldn't reach the bottom of the tank. And you may have good pressure on idle but a weak pump wont handle the need of your engine during acceleration. I replaced my fuel pump with a walbro 255LPH for $99 which had everything you need and even had that boot to replace the one i fished outta the tank. You may still have that starving while accelerating though a corner on a low tank. My HPDE instructor sd that you want to maintain the speed and not punch it or you'll starve, upset the car, and spin. He called it "Leaving some on the table" or something like that. starving on a low tank is inevitable. To change the fuel pump is really easy. Unstrap the tank or at least lower it down. Disconnect the fuel lines and wiring, hook up new one and replace the new uber better fuel pump into the tank (hardest part). It has to go in at a certain angle.
Old Dec 6, 2006 | 08:23 AM
CRX Toad's Avatar
Default Re: i need your opinion on fuel pump issue (65stang90crx)
Also you may need to do fuel pressure regulator with a bigger pump.
You shouldn't spin anyways.
Old Dec 6, 2006 | 09:08 AM
charlee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote"> My car used to starve really bad before. It was because my boot on the bottom of the fuel pump had came off and it couldn't reach the bottom of the tank. And you may have good pressure on idle but a weak pump wont handle the need of your engine during acceleration. I replaced my fuel pump with a walbro 255LPH for $99 which had everything you need and even had that boot to replace the one i fished outta the tank. You may still have that starving while accelerating though a corner on a low tank. My HPDE instructor sd that you want to maintain the speed and not punch it or you'll starve, upset the car, and spin. He called it "Leaving some on the table" or something like that. starving on a low tank is inevitable. To change the fuel pump is really easy. Unstrap the tank or at least lower it down. Disconnect the fuel lines and wiring, hook up new one and replace the new uber better fuel pump into the tank (hardest part). It has to go in at a certain angle. </TD></TR></TABLE>
thax a lot bro. i will check that. i have replaced pumps at school, but never for an ED. ik its not that hard. just was trying to get a second opinion on what the problem was. thanx a lot man, i really apreciate it. if i ever see u i will buy u taco bell
Old Dec 6, 2006 | 09:09 AM
charlee's Avatar
Default Re: i need your opinion on fuel pump issue (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">
You shouldn't spin anyways. </TD></TR></TABLE>
lol
Cameron60
Jan 16, 2007 06:04 PM
b16hatche
Dec 22, 2005 04:13 PM
crexSIvtec
Mar 5, 2005 05:10 AM
LostCRX
Apr 11, 2004 01:28 PM
