MY FS Thread, CRX and civic parts, Turbo, Race Wheels
***UPDATED 5/12/06***
Went through and added a few things, edited, merged my other FS threads into this one...
Make some lowball offers at least! I need to sell this stuff ASAP I need the money!
DSM Sidemount intercooler
Honda D series Auto tranny w/auto mounts
all sensors/pulleys anything removable from D16A6 block
D16A6 crank
working CRX sunroof assembly, minus panel
old school "H" horn button for MOMO wheel
A few stock A6 and Y8 cam gears
2 stock CRX/Civic Si exhaust manifolds/headers
some A6 flywheels (3 or 4) **2 left**
CRX rear interior panels, the big side ones, I have one for each side in ok shape, also have the top window trim for the back
EF Civic Si Dash
5 PM7 (D16A1/ZC) pistons with rods
6 D15 ACL rod bearings (enough for 3 rods)
B18 (LS) valve stem seal set
passenger side CRX Si knuckle with rotor
USDM OEM fog switch for Civic/CRX
CRX HF MAP/EGR/PCS assembly complete with box
DA B series OBD0 throttle body, no TPS (bolts up to OBD1 manifolds)
D series tranny clutch pivot arm fork thing with used (working fine) TO bearing, spring intact
DX CRX/EF exhaust manifold
4 CRX Si injectors with clips (good for MPFI!)
Nokia data cable (the one for datalogging)
D15/D16 (HF) valve cover freshly sandblasted
CRX Si rear LCA ES poly bushings **pending**
D16Y8 ignition control module, new in box from NAPA
A Cobra radar detector. Works fine, but I have a Escprt Passport X50. **pending**
Z6/Y8 valve cover (can be sandblasted/painted)
Set of D series 0.020" over Hastings rings, new in box
Box of new shiny intake charge piping (ebay looking) with blue couplers and clamps
90-93 Integra Axles, new (reman). I was going to use these on my ZC tranny but I'm going h22 and sold my hybrid tranny.
I also have 3 13x8 Keiser aluminum wheels, with 5" backspacing. They are 2-piece, currently they have 4x114 centers. I know you can get centers for whatever size you need, and you can probably get a deal on them or even a fourth wheel from FSAE. Two of the wheels are fine, one has some bends. I can inlcude a set of used slicks with them as well. One of the wheels has a tire on it with a little life left, but I have a set of 4 lightly used unmouned Hoosiers for them. These things are light! Excellent for autocross, or possibly even drag (I don't know, don't drag).
Also have a used KKK K26 turbo from an audi project car. It's the stock turbo for a Porsche 944. It's dirty from sitting around, but has no shaft play at all.
Also have a OBD0-OBD1 conversion harness, I made it. I made the one on my car too, works just fine. This one was by request of someone else who flaked on me. I can add in plugs for LC-1 if you like. This will plug into your OBD0 car and let it use a P28, P72 or other OBD1 ECU.
Pics of some stuff:
Here are the DA axles, one brand new one used very little (< one week):
Wheels (the most beat up of the three):
Integra Throttle Body:
EF Civic Si dash and Z6/Y8 valve cover:
PM7's:
D15/16 valve cover (dirty from my hands):
D16A6 crank
EF Civic Si Dash
Pics of some stuff:
PM7's:
In your first picture, you have a mandrel bend 180 degree pipe. Is that a 2.5 inch? If so, want to sell it? PM me how much you want for it... Thanks!
downest
Northeast (Sales)
Dec 19, 2006 11:15 AM
