What next?
Old Dec 5, 2006 | 04:51 PM
DarkBB4's Avatar
Default What next?
Well as many of you know, i just decided to run nitrous in my car. First impression is awsome and i plan on getting it tuned asap. Just wondering what else i could do before getting tuned that would make the nitrous Safer, or gain more power without spending TOO much money. I would consider Type S cams + adj cam gears, but is it really worth $400+ for 5whp? In addition, i would also consider a new header, but spending the difference to get a good one (rmf, rage) would be upwords of $1000 for an additional 10 whp. What else do you reccomend? I just purchased some 205/50/15 BF goodrich drag radials... Maybe Traction bar setup? or CF hood (have trunk)
Keep in mind, I want to run as LOW 1/4 times (so no subwoofers or etc)
what type of times u think i could pull this season?
I ran 14.4 @ 100 w/ 2.29 60ft on 205/50/15 nitto 450's (NO TRACTION) w/o spray
Engine- Swapped JDM H22a
Internal Mods:
* Removed Balance Shafts, Manual Tensioner conversion
Motor Mods:
* 1 of a Kind Password JDM CF intake chamber
* Megan Racing header with 2.25 Collector mod (heat wrapped)
* Test Pipe to 2.25" exhaust to RSR exmag muffler
* Magnaflow 18" Resonator
* Fuel pressure regulator
* NGK blue wires
* Shaved Valve Cover
* Zex Nitrous Sleeper Install
* Exedy Clutch,
* JUN flywheel
* P28 Uberdata
* C+R racing radiator
* Spoon Radiator Cap
* SS clutch line
* Odyssey Lightweight battery
* ES motor mount inserts
* Driveshaft Shop axles
* Magnetic Tranny/Oil drain bolts
* Hondata Intake Manifold Gasket
* Carbing Catch Can
Old Dec 6, 2006 | 08:31 AM
DarkBB4's Avatar
Default Re: What next? (DarkBB4)
BUMP for 13's all motor
12's on spray
I WISH!
Old Dec 6, 2006 | 09:06 AM
The Birdman's Avatar
spoon radiator caps and stainless steel clutch lines are engine mods? haha jk, I would say cams + valvetrain + adj cam gears = good amt of power for the money. But I would not say to get type s cams.... so I don't know if that's still in your budget.
Old Dec 6, 2006 | 09:13 AM
92blkJDMh22's Avatar
2 step colder plugs......
Old Dec 6, 2006 | 09:53 AM
DarkBB4's Avatar
Default Re: (92blkJDMh22)
ya i just took amod list that i made previously
i already have ngk7es so im all good there
Old Dec 6, 2006 | 10:02 AM
98vtec's Avatar
moderator emeritus
Default Re: (DarkBB4)
MSD window switch
Old Dec 6, 2006 | 10:04 AM
mgags7's Avatar
13s all motor is easy.....12s would be niceeee
I'll be running my car this spring with some more power....mmmm
GET CAMS!
Old Dec 6, 2006 | 03:12 PM
DarkBB4's Avatar
Default Re: (B.Rabbit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.Rabbit &raquo;</TD></TR><TR><TD CLASS="quote">MSD window switch</TD></TR></TABLE>
explain
Old Dec 6, 2006 | 03:34 PM
championshipwhite93si's Avatar
want 13's... s300 with a tune, jun cams an valve train, rmf... should be nice with the drag radials
Old Dec 6, 2006 | 03:43 PM
DarkBB4's Avatar
Default Re: (championshipwhite93si)
I actually think i can hit 13.9 or so in its current state (w/o n20)
Traction was a HUGE issue before.. spinning through first and second
now w/ the drag radials at low pressure , i plan to cut 1.9-2.0 60fts and I will be tuned...
hoping on 190-200whp so we'll see
then 260-270whp with the nitrous I hope to see low 13's at the track... I CANT WAIT!
Old Dec 6, 2006 | 04:37 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">explain</TD></TR></TABLE>
a window switch is a relay based on rpm that wont allow nitrous to be sprayed over the selected rpm. So basically it protects you from spraying during a misshift and it can shut off the nitrous just before you shift.
Its a protection type thing.
Pullig
Jun 11, 2008 08:07 PM
Legion
Apr 17, 2007 07:56 PM
crxhybrid85
Aug 10, 2005 04:10 AM
ebp_dc2
Apr 25, 2005 02:38 PM
sirlock
Jul 17, 2001 09:59 AM
