Undoing a WW kit, or the permanentability of one?
Old Dec 5, 2006 | 03:12 PM
Vovchandr's Avatar
Default Undoing a WW kit, or the permanentability of one?
I got a 89si and a 90 Si, my 89 si is my baby and its going to have a clean OEM look, but i've always loved the WW look as well, so I figured I'd drop it on my 90si.
I already have the whole kit and all.
My question is, if i ever decide to, for whatever reason to go back to the OEM look how hard would it be to "convert" it back.
The lower door moldings look to be a pita if not impossible to put back on?
Or is it fully "reversable" to return to OEM without any major headache?
Yes, the kit is urethane, only the good stuff
Old Dec 5, 2006 | 04:41 PM
daveb91's Avatar
Default Re: Undoing a WW kit, or the permanentability of one? (Vovchandr)
Nothing on the kit is permanent
Old Dec 6, 2006 | 04:20 AM
Vovchandr's Avatar
Default Re: Undoing a WW kit, or the permanentability of one? (daveb91)
So all the side moldings and door moldings will go back on right?
The lower door molding looks like a pita..
Old Dec 6, 2006 | 05:59 AM
Boosted Chemist's Avatar
the ww retains the lower molding, so it should be under your sideskirts. You can switch back without any problems
Old Dec 6, 2006 | 06:04 AM
crxnj's Avatar
just watch out how you install the door panels...i know alot of people use pop rivets or sheetrock screws for them,,,just use the doubleside tape instead..then when you remove it will be easy. just heat the door panles,remove them,use goo-off or what ever for the thick glue ,,then use a good wax to get the rest of the **** off
Old Dec 6, 2006 | 06:28 AM
glagola1's Avatar
Default Re: Undoing a WW kit, or the permanentability of one? (mr.speaker)
If you use just the double sided tape you won't have to worry about taking off the panels because they'll just fall off on their own.
Pandahatch
10
Aug 19, 2015 11:31 PM
Dominicandude
Feb 11, 2006 01:46 PM
fozzy1
May 21, 2004 07:45 AM
CrazyHondaBoy
Dec 19, 2003 10:46 AM
AznInvasion
Jan 20, 2003 08:29 PM
