CRX WIRING QUESTION!!
Old Dec 5, 2006 | 01:13 PM
CO_CReX's Avatar
Default CRX WIRING QUESTION!!
Ok all you Wiring Gooroos. I have a 88-89 under the dash harness and I want to use the 90-91 gauge cluster. Well I believe I have all of that wired up correctly thanks to one of my previous posts. Well now I have run into another problem. All the plugs for the hazards, rear defrost, dimmer etc are all different. And I really want to use the 90-91 CRX gauge cover because it looks nicer. My question is, the gauge cluster wiring and all those little switches are on a seperate harness that disconnects from the fuse box, can I just pick up that part of the harness from another 90-91 CRX/EF and plug it right into my 88-89 fuse box? Or do I have to use the 90-91 fuse box? OR should I just try and come up with a complete 90-91 CRX/EF harness?
Old Dec 5, 2006 | 02:13 PM
Suck my DX's Avatar
Default Re: CRX WIRING QUESTION!! (CO_CReX)
just swap the connectors
TehTaylor
Apr 14, 2013 09:34 PM
donaldmejr
Nov 29, 2008 10:40 AM
crvpimpin
Feb 25, 2008 11:08 AM
4DRmafia
10
Jan 7, 2007 07:21 PM
