BAD heat - did research couldnt find any answers please help
Old Dec 5, 2006 | 12:54 PM
blakacintegra's Avatar
Default BAD heat - did research couldnt find any answers please help
ok i have a 94 integra gsr and the heat was barely even warm at all when it was coming out and i never switched the thermo so i did that first because its cheap and you cant go wrong with that...i am going turbo so i bought one of those thermos on ebay that open at a colder degree i guess? and i flushed the whole colling system ,filled with new coolant, bleed the system and im pretty sure i did everything correct..the heat became a little warmer but not good enough for whats to come within the next couple weeks! whats my problem? my switch to go from cold to hot on my panel is broken so how i switch it is under the dash on the passenger side you can see the cable and what it hooked up to so i just used to push that plastic piece back and forth and everything used to be good , i recently took out my AC i dont know if that could have an effect or what? any ideas?
Old Dec 5, 2006 | 01:50 PM
str8JDMteggy's Avatar
The valve that lets the coolant into your heater core might be stuck shut. Follow where the hearter core goes to the car and move it with your hand. There will be 2 cables on it.
Old Dec 5, 2006 | 02:39 PM
Default Re: (str8JDMteggy)
alright ill try that...move it as like shake it around and it will open up the valve?
Old Dec 5, 2006 | 03:38 PM
Old Dec 5, 2006 | 04:11 PM
are you talking about that little lever that the cable is hooked onto or something else?
Old Dec 5, 2006 | 07:59 PM
bump for HEAT
Old Dec 5, 2006 | 08:50 PM
i moved the lever but it still does the same thing..could it have anything to do with the coolant system or the theromstat that i have?
Old Dec 5, 2006 | 08:56 PM
DatDBisNaSty's Avatar
Bad blower motor?
Old Dec 5, 2006 | 09:14 PM
how do i test that, just by replacing it?
Old Dec 6, 2006 | 06:25 AM
Default Re: (blakacintegra)
bump
Old Dec 6, 2006 | 07:03 AM
Ichigo's Avatar
You should go to your nearest autoparts store and buy a new thermostat for your integra. Get a regular one. You don't need to get any of the premium or nothing. Ebay stuff are really crappy, and a thermostat from an autopart store is no more that $10. Go buy a real one and not ebay. I just don't trust ebay that much with their quality.
in addition, if you bought a lower temperature thermostat, that means your car warms up slower than a thermostat with a higher temperature. I think. Its been a while since i did my own thermostat so i'm not quite sure.
Modified by Ichigo at 4:20 PM 12/6/2006
Old Dec 6, 2006 | 07:07 AM
buy a blower motor and thermostat your saying?
Espiea
Sep 15, 2017 10:18 AM
Ohannon7
Nov 30, 2008 06:08 AM
ColMustard
Jan 5, 2008 10:34 PM
Blaze45
15
Sep 23, 2006 02:54 PM
ohsnapzafingcu
Jan 7, 2006 04:31 PM
