HELP! With Codes.
well i cant help ya.. the ecu code troubleshooter help me alot.. the links just might be down for a bit. just keep trying.. if not then im sure someone will be able to help ya.
it plugs into the switch beside the oil filter in this pic (ignore teh stainless line as that won't be on your block)
it might help to post what engine you are putting in, ECU, etc? Looks like from the header shot you are doing an OBD1 engine due to the O2 sensor location in the header collector. I'm not sure what it will do if anything by placing the O2 lower in the stream but it may cause some issues.
I could be wrong but the other plug looks like its for a piece of emissions equipment found on the intake manifold of OBD0 civic/crx Si/HF but you won't have to use it if you are using a newer engine.
My bad.
My engine is an LS.Vtec
JDM B16 head on a ls bottom (90 DA).
The Thing that you posted the picture of is for the black plug right? Mine broke off and had to be plugged and welded off. So I don't have one.
I thought the other was for the map sensor. but I have both plugs in the map sensor. So IDK.
THANKS though.
THANKS though.
the intake air temperature sensor in the sensor on this pic on the right that is white, make sure yours is plugged in
make sure this is plugged in also
the last code sounds distributor related, did you do any distributor modifications, adaptors, convert from DPFI to MPFI etc?
I have the air intake temp sensor pluged in.
Is it the plug in that's on the same loom as the injectors? I had two that fit, but assumed that the one on the injectors was the right one.
I will check the other sensor in the morning.
I haven't done anything to the Dizzy... But I will have my friend take it apart and see what's what.
Thanks.
Thanks.
RVCA97
Dec 28, 2005 09:24 AM
