Water pump/ Oil pan
Could I just use a 4th gen gasket ? Or does permatex or other gasket maker work better ?
Also you talking about the oil pan correct that doesnt have a gasket ?
Honda-Bond.
If you use a 4th gen oil pan on a 5th gen, use the 4th gen gasket.
If you use a 5th gen on a 4th gen, use honda-bond as well as the small gasket that goes by the rear mail seal.
