valve cover removal...
Is removing the valve cover as simple as removing the screws or is there more involved. I want to remove it to completely scrub it clean, but I need to know if I'm going to need a new gasket or any other pieces before I do this. Thanks a lot.
its as simple as removing all the bolts, i think thers 8 or so of them. Just be careful removing it. While you should get a new gasket and spark plug gaskets, If you inspect the current ones, and they don't appear messed up, you should be just fine in using the stock ones.
Evan
Evan
u have to disconnect the wire going to the alternator and move it out of the way.....remove the bolts holding the valve cover and bracket for the p/s hose....remove pcv valve and breather hose....get a new valve cover gasket and hondabond
