Turbo eclipse or gsx injectors possible on DPFI?
Old May 10, 2002 | 11:04 AM
JALOP B16's Avatar
Default Turbo eclipse or gsx injectors possible on DPFI?
with out going MPFI
Old May 10, 2002 | 11:05 AM
markedOO1's Avatar
Default Re: Turbo eclipse or gsx injectors possible on DPFI? (JALOP B16)
here's a question, why?????
they'll probably fit but you're ecu isnt going to be able to run injectors that big...
Old May 10, 2002 | 11:39 AM
g4b17's Avatar
New User
Default Re: Turbo eclipse or gsx injectors possible on DPFI? (marked001)
it should work, Eclipse injectors are low resistance like honda ones. stock eclipse injectors are 450cc.
[Modified by g4b17, 12:40 PM 5/10/2002]
Old May 10, 2002 | 11:47 AM
ImportHatch's Avatar
Default Re: Turbo eclipse or gsx injectors possible on DPFI? (g4b17)
the turbo 5 speed ones are 450cc the other ones are not.
Yager-
Old May 10, 2002 | 12:03 PM
WuShu's Avatar
New User
Default Re: Turbo eclipse or gsx injectors possible on DPFI? (ImportHatch)
man you must be lazy
Old May 10, 2002 | 12:19 PM
Urban Business
Guest
Posts: n/a
Default Re: Turbo eclipse or gsx injectors possible on DPFI? (HondaCRX)
you will need to run an external afc to control them. a larger pressure reg will also be needed. convert to mpfi and run the injectors w/ fuel rail, pressure reg, high flow pump and an afc for best results. stock ecus cant handle them at all
Old May 10, 2002 | 12:25 PM
markedOO1's Avatar
Default Re: Turbo eclipse or gsx injectors possible on DPFI? (TorteX)
once again, why????? haha.
Old May 10, 2002 | 12:29 PM
Urban Business
Guest
Posts: n/a
for turbo, sc or nitro
[Modified by TorteX, 3:29 PM 5/10/2002]
Old May 10, 2002 | 12:32 PM
markedOO1's Avatar
I realize that...but you'd be crazy to do that on a dpfi setup..
Old May 10, 2002 | 12:37 PM
Urban Business
Guest
Posts: n/a
i agree hence me saying convert to mpfi. not crazy just inefficient
[Modified by TorteX, 3:38 PM 5/10/2002]
Old May 10, 2002 | 11:16 PM
JALOP B16's Avatar
Im asking for a friend
I dont have a piece of **** dpfi engine!!!
Old May 10, 2002 | 11:19 PM
JALOP B16's Avatar
what would be a good injector for this type of engine?
I told him to go mpfi but thinks its to much work
he's scard
Old May 11, 2002 | 06:48 AM
Mugen Dom's Avatar
there is no way to upgrade the injecters on a dpfi intake manifold...and im not even gonna say how i would do it cause it wouldnt be capable of him ot do or pull off if hes scared to use mpfi
jdmsohc94
Apr 13, 2008 03:22 PM
DriveSlowHomie
Feb 18, 2005 11:59 AM
yellowbuffalo
Dec 9, 2002 03:11 PM
Hayasa15
Jan 28, 2002 07:24 PM
