Steering wheel swap
Hi all, how hard is it to do a steering wheel swap for a aftermarket one in a 96-00 body style civic and is it worth doing???
Thanks in advance!!!!!!!
My stock one is a little chewed up at the top and I was looking on eBay for a aftermarket one, a real Honda one would be to much $$$$
You'll lose your airbag.
It's real easy. Unplug your battery. Removed the air bag, disconnect the wire, remove 17mm bolt and pull out the wheel.
There's a DIY somewhere. Search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">If you get a "Momo"-style wheel, you'll need an adaptor hub made for your car.</TD></TR></TABLE>
And while your at it. Get a quick release kit with lock.
https://honda-tech.com/zerothread?id=1783138
https://honda-tech.com/zerothread?id=1003492
https://honda-tech.com/zerothread?id=1626686
GReddyTurboCoupe
May 23, 2005 01:44 PM
