anyone know if i can run 88mm pistons safely with stock sleeves? h22a block?
Old Dec 5, 2006 | 07:47 AM
hondafiend's Avatar
Default anyone know if i can run 88mm pistons safely with stock sleeves? h22a block?
anyone know if i can run 88mm pistons safely with stock sleeves? h22a block? i got some pistons but need to know if i can bore the stock 87mm to 88 safely? anyone??
Old Dec 5, 2006 | 07:53 AM
Revi's Avatar
Default Re: anyone know if i can run 88mm pistons safely with stock sleeves? h22a block? (hondafiend)
are they OEM oversized pistons or aftermarket forged? If they are forged your gonna have to sleeve the block. If they are OEM you can get a bore and hone job and put em in.
Old Dec 5, 2006 | 08:09 AM
hondafiend's Avatar
Default Re: anyone know if i can run 88mm pistons safely with stock sleeves? h22a block? (Revi)
OEM oversized. cool. just wanted to know before i put them in! thanks!
Old Dec 5, 2006 | 08:17 AM
117's Avatar
117
I have never seen a Honda 1mm OS piston for an H22. The only thing I've seen is a 0.25mm OS H22 piston. Are the pistons you have Honda OEM? What is the PN?
Old Dec 5, 2006 | 08:38 AM
Revi's Avatar
Default Re: (117)
^True. Find out exactly what you got.
Old Dec 5, 2006 | 08:40 AM
2lude4u's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">I have never seen a Honda 1mm OS piston for an H22. The only thing I've seen is a 0.25mm OS H22 piston. Are the pistons you have Honda OEM? What is the PN?</TD></TR></TABLE>
Exactly, the FRM is only .5mm thick (or less). So if you you bore out further you no longer have FRM cylinder walls & what is left is not suitable as a cylinder wall material. That's why OEM OS pistons are still rather close to 87mm. Any larger than that requires sleeving.
Modified by 2lude4u at 11:20 AM 12/5/2006
Old Dec 5, 2006 | 09:08 AM
hondafiend's Avatar
not an exact oem, a copy, available in 87 87.5 and 88mm, stock casting not forged and pretty cheap at 200 bucks for all 4 with rings and pins. so 88 is too big to bore for stock sleeves? getting conflicting info here????
Old Dec 5, 2006 | 09:19 AM
hondafiend's Avatar
so how big can i go with a stock sleeve? 87.5? or just .025 over? or should i just stick with the stock 87mm bore? anyone?
Old Dec 5, 2006 | 09:21 AM
2lude4u's Avatar
If you don't want to sleeve it, then stay at the stock bore.
Revi's Avatar
Your gonna need to sleeve the block to run those pistons, you cant bore out the stock sleeves that big.
Old Dec 5, 2006 | 10:19 AM
vinuneuro's Avatar
To reiterate, the most you can bore the stock sleeves is to 87.25mm. Any more, and you will damage the fibers in the frm. If you want more, you'll need to resleeve.
Old Dec 5, 2006 | 12:47 PM
hondafiend's Avatar
Default Re: anyone know if i can run 88mm pistons safely with stock sleeves? h22a block? (vinuneuro)
oh well, i guess i'll just stick with the 87 bore. thanks.
boostedh22lude1
Oct 18, 2007 07:43 AM
hybrid2007
Jul 1, 2007 03:54 PM
speedyonez
Jun 28, 2005 11:20 PM
sleeper324
Jan 11, 2005 09:34 AM
JDM97R
Jul 21, 2004 11:58 AM
