what parts can i use from my accord on the h22a
[B][B]i have a f22 in the car right now with, lightened flywheel , stage 3 race clutch, and headers, i know i can use the clutch and the flywheel but can i use the header still ? also is there any thing i should look for when doing this swap ??? 1992 accord ex / H22A, *its a pretty basic swap <this i know! What's up everyone help me out .
you cant use the header... if your f22 is non vtec you will need to watch the wiring for that. when we did my friend's prelude swap we had some trouble with the distributor and vacuum lines.. id say find a friend who knows exactly what they are doing or find a diagram. good luck.
Thanks for the info, btw do you know what ecu would be the best to use a(p13)? thats usdm right? i would like to plug n play jdm any idea's?
Thanks!
Thanks!
