After replacing front rotors, pedal feels a little spongy.. Why?
The car has 12k miles and the reason I need to change the OEM rotors is because they are warped from couple track events. I swapped them out with AutoZone's (the correct part number, I checked) and after the first test drive, the pedal feel is not as keen as before. Seems like the grab is less sensitive, but why? Will the pedal feel better after I put some miles on it? Both pads and fluids are still original..
[Modified by typeRP, 11:48 AM 5/10/2002]
bleed your baakes anyway... it can't hurt.
Will
-who is breaking in a new set of r0t0rs
go bed your pads in
do about 6 30-40 mph stops and 4 40-60 mph stops (both sets down to 5 mph) then drive slowly and let your brakes cool and then park your car for a few hours.
after that you'll be good to go
-jeff
-jeff
Thanks again guys (APenny and Willard)...
What fluids do you recommend?
FYI... my pedal is nice a firm now.... ~2 weeks after the rotor install.
Will
You used your stock pads at a track and you still have them on? What kind of shape are they in? After one track day mine were white and crumbling to the touch.
Stock pads are poo at the track
If you warped your rotors - your stock pads might be glazed - did you rough them up before putting them back on??
Careful that you bed the pads properly - and always give lots of time for cool down. Also never wash your car if the brakes are still hot - that will warp them too.
drive4fun
Jan 4, 2008 07:59 AM
Saintor
Dec 7, 2004 10:08 PM
