Suspension & Brakes Theory, alignment, spring rates....
is it possible to be slammed and have correct camber?
Old Dec 4, 2006 | 10:12 PM
alacard's Avatar
Default is it possible to be slammed and have correct camber?
on my setup right now i neglected to get a camber kit and my tires are showing it...but i love my ride height. is it possible to tuck your wheels with correct camber? it seems that if the camber was straightened out like its supposed to be that the wheels would hit your fenders instead of going under them like they do with bad camber...do all these slammed cars just go through tires like crazy?...or am i just overthinking it all too much?
Old Dec 5, 2006 | 05:09 AM
future62
Guest
Posts: n/a
Default Re: is it possible to be slammed and have correct camber? (alacard)
No...toe is more important anyway.
Old Dec 5, 2006 | 07:26 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: is it possible to be slammed and have correct camber? (future62)
A little bit of camber is good due that when you go into corners and your body rolls slightly it will roll onto the contact patch of the tire. If you got alot of camber be prepared to buy tires. And what he said about the toe is also true.
Old Dec 5, 2006 | 07:39 AM
PIC Performance's Avatar
If rubbing is going to be a concern, you can roll the fenders and that should help a little. But in most cases where you are tucking your tires, the tires (and handling) will benefit more from simply raising the car up a bit.
Old Dec 5, 2006 | 08:39 AM
BuiltforSin's Avatar
get a tire like the nitto neo-gen. the neo-gen was designed to reduce the amount of wear on the inside of the tire with lowered vehicles.
Old Dec 5, 2006 | 01:13 PM
alacard's Avatar
hmm...so basically if i want to tuck my wheels, im gonna have tire wear on the inside.....i know toe is more important but camber makes you go through tires...so therefore, camber is important too. (to me atleast)...thanks for the input guys, anyone else?
Old Dec 5, 2006 | 02:23 PM
future62
Guest
Posts: n/a
Default Re: (alacard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">hmm...so basically if i want to tuck my wheels, im gonna have tire wear on the inside.....i know toe is more important but camber makes you go through tires...so therefore, camber is important too. (to me atleast)...thanks for the input guys, anyone else?</TD></TR></TABLE>
Camber in itself won't kill your tires, especially if you rotate them regularly. Improper toe + camber = certain death. Get a good alignment and rotate your tires and you should be fine.
Old Dec 5, 2006 | 02:27 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">on my setup right now i neglected to get a camber kit and my tires are showing it...</TD></TR></TABLE>
you neglected to get an alignment to fix your toe change.
Old Dec 5, 2006 | 02:39 PM
TunerN00b's Avatar
Default Re: is it possible to be slammed and have correct camber? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">you neglected to get an alignment to fix your toe change.</TD></TR></TABLE>
Agreed, toe kills tires, not camber.
My weekend car has run -4.75* rear camber since I bought it. I killed the first set of tires in 6 months. Did an alignment and fixed the insane rear toe it was suffering from (old sagging spring gave an additional degree of camber, but a ton of toe out) by removing the toe shims and left the camber. I've had the current set of tires for 8 years and 14k miles now, and they do not show any signs of "camber wear". Tire tread gauge shows nearly even wear across the entire tire, with a little more wear on the outside shoulder (I'd love an explanation for this) and 75% of the tread left.
Once you driven a car with nearly 5 degrees of negative camber, and everyone in the world has asked you "Wow, how much did you have to lower the car to get the insane camber?" and you still don't see any unusual tire wear, you start to wonder how much "camber wear" is really toe wear.
Old Dec 5, 2006 | 10:10 PM
alacard's Avatar
no, i got an alignment. they adjusted the toe but obviously couldnt touch the camber...so im trying to figure out where my inside tire wear is coming from if everyone says camber doesnt kill tires.
Old Dec 5, 2006 | 10:12 PM
Tyson's Avatar
alignment printout?
Old Dec 5, 2006 | 11:24 PM
dvp's Avatar
dvp
Camber does wear tires, just not as bad as toe does. If he's "slammed" ( I hate that word) he might have as much as 3+* of camber...not good for tires.
If you're lowered past 2" you need a camber kit, specially if all you do is DD.
Old Dec 7, 2006 | 08:57 AM
alacard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">alignment printout?</TD></TR></TABLE>
i'll have to take a picture of it and post it up..ill get it on here sometime today
Old Dec 7, 2006 | 11:39 AM
PBzAllan's Avatar
i feel you on that my rear camber is pretty bad...=[ im on my 2nd set tires its barely comin to the 3rd month
Old Dec 8, 2006 | 02:35 PM
nonsense's Avatar
Default Re: is it possible to be slammed and have correct camber? (PBzAllan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PBzAllan &raquo;</TD></TR><TR><TD CLASS="quote">i feel you on that my rear camber is pretty bad...=[ im on my 2nd set tires its barely comin to the 3rd month </TD></TR></TABLE>
What did you have them set rear toe at when they aligned it?
HondasGetDown
Apr 3, 2018 12:41 PM
qhondak
Suspension & Brakes
Jan 31, 2008 08:07 AM
madlion
Oct 8, 2006 09:16 AM
alex_s817
Apr 17, 2006 07:51 PM
theguy003
Jan 25, 2002 05:08 PM
