D15B cold start issues
Old Dec 4, 2006 | 06:26 PM
eg6madness's Avatar
Default D15B cold start issues
i installed a D15B in a civic, when the cars starts from cold it sputters badly. it starts sounding like it is running on 2 cylinders with fowled plugs . back firing badly and popping.
The timing i accume is out.
i have the crank pulley at TDC, the cam gear has a Pointed ( little triangle ) to the right of that there is a semi-circle also cut . do i align the cam gear with the triangle or with the semicircle. when i put it at the triangle the car runs really slugish and doesnt pull hard at all. with it between the triangle and the circle the car seem ok, and close to the circle the car runs good.
The distributor is set to 16 degrees.
Also the check light doesnt go off, from the time the key is in and the ignition is turn on it never goes off.
If i try to bridge the ECU to get the code. that doesnt even work . i tried 2 different ECUs in the car and both give me the same results .....
any ideas on what can be those problems
Old Dec 5, 2006 | 02:02 AM
eg6madness's Avatar
Default Re: D15B cold start issues (eg6madness)
anyone
Alanhino
May 26, 2012 02:11 PM
eg6madness
Dec 7, 2006 03:09 PM
thresher
Aug 22, 2006 08:19 PM
DOHClessEF-9
May 9, 2005 10:17 PM
JaiDM
14
Jan 6, 2003 04:58 PM
