12.5 CR Timing, hondata
Old Dec 4, 2006 | 05:40 PM
Yambor's Avatar
Default 12.5 CR Timing, hondata
Well guys, ive been out fuel tuning my gsr lately and im getting 12.8-13.2 WOT..
now heres my ? to you..
I WAS running 28.75deg timing column 10, 8950 rpm..high cam..
ive heard thats too much from two people.. they said down in the low 20's is good..
this is on 93 pump gas..
base timing was 17.75deg,,
ive proceeded to remove timing, now high cam is 20.75 and low cam is 20.00
too less, needs more etc?
ive read high 20's are fine as well too..
im just looking for some input here, any help would be great. thanks!
Old Dec 4, 2006 | 06:14 PM
camlob's Avatar
Default Re: 12.5 CR Timing, hondata (Yambor)
I just took off timing from the low cam. From 35 its now 25. My big cam is 15!
Old Dec 8, 2006 | 12:43 AM
chameleon's Avatar
Default Re: 12.5 CR Timing, hondata (camlob)
best way to figure out where your motor likes timing is on the dyno.. raise timing until it stops making power .. then back it up 2 degrees.
Old Dec 8, 2006 | 01:59 AM
chris2000's Avatar
Just to share what i have seen:-
1)B16A + PCT pistons + mill ported head + TODA C tune with 31.75 ign column 10 from 7500rpm to 9000rpm with 100 octane fuel
2)B16A + PCT pistons + std head + GSR cams with 32 ign column 10 at high revs on 95 octane fuel
3)B18C5 with TODA C with 30 ign at column 10 at high revs on 95 oct fuel
Old Dec 8, 2006 | 02:02 AM
chris2000's Avatar
Default Re: 12.5 CR Timing, hondata (chris2000)
To add another thing, i just check my hondata base map and it was 27.25 from Hondata already at 8950rpm high cam
Old Dec 8, 2006 | 06:50 AM
b19coupe's Avatar
28-31 on the high cam. Most motors like the timing to taper off slightly above 8,000 rpm. The timing should ramp up on the low cam and be anywhere from 23-26 at VTEC switchover. The only way to know for sure what your motor likes is to get it on a dyno.
Old Dec 8, 2006 | 10:26 AM
Rocket's Avatar
Default Re: 12.5 CR Timing, hondata (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">28-31 on the high cam. Most motors like the timing to taper off slightly above 8,000 rpm. The timing should ramp up on the low cam and be anywhere from 23-26 at VTEC switchover. The only way to know for sure what your motor likes is to get it on a dyno.</TD></TR></TABLE>
Old Dec 8, 2006 | 10:33 AM
600 c dans rule's Avatar
B A N N E D
Default Re: 12.5 CR Timing, hondata (Don Lackey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Lackey &raquo;</TD></TR><TR><TD CLASS="quote">
Hey are you related to Brad Lackey? You should hear him do engine sounds with his mouth.
Old Dec 8, 2006 | 10:46 AM
Rocket's Avatar
Default Re: 12.5 CR Timing, hondata (600 c dans rule)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 600 c dans rule &raquo;</TD></TR><TR><TD CLASS="quote">
Hey are you related to Brad Lackey? You should hear him do engine sounds with his mouth.</TD></TR></TABLE>
Yeah you know him? His uncle was WiseAss McGee and an in-law to Tired of Jason's Mouth. Last I heard of him he was attending political correctness school.
Old Dec 8, 2006 | 04:38 PM
B A N N E D
Yeah you know him? His uncle was WiseAss McGee and an in-law to Tired of Jason's Mouth. Last I heard of him he was attending political correctness school.</TD></TR></TABLE>
WHAT the hell are you talking about??? I'm talking about the old motocross rider with the beard that rode for Kawasaki
Old Dec 9, 2006 | 04:48 AM
D-Rob's Avatar
Wow, the values on Hondata must be VERY different than the values on Crome/Uberdata.
My max timing on the high cam is like, 23 degrees.
You still bringing the H2B car tonight, or did you get some tags for the GSR?
Old Dec 9, 2006 | 11:23 AM
Yambor's Avatar
Default Re: 12.5 CR Timing, hondata (D-Rob)
yea, but didnt john redo your timing? he is the one that told me to set the timing lower than what i had it, which is a respectable opinon..
and guys i am fully aware to tune ignition on a dyno, i just didnt want to run too much breaking it in doing fuel tuning, thanks..
Old Dec 9, 2006 | 11:39 AM
D-Rob's Avatar
Yes, John did redo my timing maps a little bit, although I'm not positive as to what exactly he did with them.
scUba-stEve
13
May 15, 2005 08:47 PM
iperez
Apr 2, 2004 11:57 AM
12 oz.
Jun 1, 2002 07:47 AM
eargrub
May 16, 2002 11:00 AM
