Is the JDM DC 4-1 bolt on?
Old May 10, 2002 | 09:40 AM
tweekerz's Avatar
Default Is the JDM DC 4-1 bolt on?
I was talking to the local performance shop and they told me that the cat will need to be shortened due to the length of the JDM DC. Is this true? If you use this header with the stock cat it is no longer removable from the header? TIA!!!!
Old May 10, 2002 | 09:45 AM
dohcsideSi's Avatar
Default Re: Is the JDM DC 4-1 bolt on? (GoodTimes)
true it does not bolt up to the cat due to it being 2.5in although it should come w/a adapter flange, your best bet is to get an a/m cat or shorten the b-pipe. modifing you stock cat in any way is illegal.
Old May 10, 2002 | 09:47 AM
tweekerz's Avatar
Default Re: Is the JDM DC 4-1 bolt on? (dohcsideSi)
So if I get an aftermarket cat it will bolt on without any hassell? Do you know what brand cat is compatible?
Old May 10, 2002 | 09:53 AM
comptechgsr2000
Guest
Posts: n/a
I got my high flow cat from SMSP. Try to IM him. I also got a test pipe from him.
Both fit perfectly! Thanks SMSP
Old May 10, 2002 | 09:55 AM
tweekerz's Avatar
Default Re: Is the JDM DC 4-1 bolt on? (comptechgsr2000)
How do you feel about the gains with the test pipe? I heard they rattle sometimes, and the smell comes up inside the cabin. Is that true?
Old May 10, 2002 | 11:59 AM
comptechgsr2000
Guest
Posts: n/a
It doesn't rattle but it smells sometimes. when the car is moving I don't smell anything, it's only when I'm at a light and my windows are rolled down
98civicEX
Mar 10, 2003 07:42 AM
12 oz.
May 28, 2002 11:48 AM
bananacruzier
Feb 14, 2002 10:50 AM
threatcon13
Nov 19, 2001 08:40 AM
NSX Bob
Sep 7, 2001 03:55 AM
