96 accord 4cyl..ground control ?? slammed.
Old Dec 4, 2006 | 04:32 PM
89POS's Avatar
Default 96 accord 4cyl..ground control ?? slammed.
i finally got my GCs a week ago after researching the differant brands and almost going with full coilovers. im happy with the ride and quality of them. hers the question..
i put the front down as far as it goes(im on 17s) and i get a slight bounce. im still on stock shocks all the way around, my pretty sure the fronts are on their way out(i know theyre on their way out,correction) would agxs or tokicos ,in the front only(im satisfied with stocks in the rear for now)hold up to that kinda drop or would i be better off with konis?? i got an off the shelf set also so would i be able to fit konis if i wanted?
thanx for the input and opinions.
Old Dec 4, 2006 | 04:36 PM
iam7head's Avatar
Default Re: 96 accord 4cyl..ground control ?? slammed. (89POS)
agx will not warrany anything over 1.5 inch drop, so you are better off with koni with shortened body all four corner.
Old Dec 4, 2006 | 04:39 PM
89POS's Avatar
Default Re: 96 accord 4cyl..ground control ?? slammed. (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">agx will not warrany anything over 1.5 inch drop, so you are better off with koni with shortened body all four corner.
</TD></TR></TABLE>is that special order or shelf??
youve personally rode on them??
Old Dec 4, 2006 | 04:48 PM
iam7head's Avatar
rode on gc/koni all the time
Old Dec 4, 2006 | 05:01 PM
AJ06's Avatar
The the Tokico illuminas or the Koni's
Personally Im getting the Illuminas and we'll see what happens
Midori Green
Dec 24, 2006 10:11 AM
jakeiscool
Suspension & Brakes
Jan 25, 2005 06:36 PM
SlammedCD7
May 13, 2004 06:40 AM
ANGELIQUE
18
Feb 27, 2004 07:05 PM
Civicpmp4
15
Feb 2, 2004 07:48 AM
