Suspension & Brakes Theory, alignment, spring rates....
Camber kit install problem`
Old Dec 4, 2006 | 04:21 PM
DC4 me's Avatar
Default Camber kit install problem`
sup guys, i have a 99 integra ls, and i was trying to change out my camber arms today.
I unbolted the 2 nuts on the strut tower, let it drop down, but i couldnt get the part thats connected to the suspension with that rubber boot thingy to come off. what do i have to do to get it to come out of its place?
Old Dec 4, 2006 | 04:53 PM
Tyson's Avatar
Default Re: Camber kit install problem` (lghnea)
i have no idea what youre talking about. use numbers.
what camber kit?
Old Dec 4, 2006 | 05:51 PM
02 accord's Avatar
Default Re: Camber kit install problem` (Tyson)
I think he's talking about the upper ball joint.
Old Dec 4, 2006 | 07:19 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: Camber kit install problem` (02 accord)
loosen the nut on the ball joint, but dont take it completely off. Take a big hammer and hit the designated spot on the knuckle. U will see what I am talking about when u get under there. Keep hitting until the ball joint pops out. The hammer will cause vibrations, and the vibrations will eventually make the ball joint pop out
Old Dec 4, 2006 | 07:58 PM
dvp's Avatar
dvp
Default Re: Camber kit install problem` (rukawa1one)
Or you could use a ball joint sepperater like you're suposed to.
Old Dec 5, 2006 | 09:35 AM
Tyson's Avatar
Default Re: Camber kit install problem` (dvp)
hammer is the better way of taking a balljoint off. and by far the easiest.
pickle forks will most likely damage the balljoint and rip the boot.
pullers can bend the threaded stud.
Old Dec 5, 2006 | 01:13 PM
dvp's Avatar
dvp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">hammer is the better way of taking a balljoint off. and by far the easiest.
pullers can bend the threaded stud.</TD></TR></TABLE>
That's why you leave the nut on the tip of the threads. That way it wont bend.
Modified by dvp at 12:29 AM 12/6/2006
Old Dec 5, 2006 | 04:50 PM
TunerN00b's Avatar
I had no issue using a Pep Boys rented "pickle fork" to remove my upper ball joints. I wasn't planning on reusing them, so I wasn't very careful taking it off, and everything still seemed undamaged. Of course, YMMV.
Actually, I even did it with the wheels still on the car, since I had "lost" my wheel locks when my car was broken into, and there's just enough room between the tire and fender.
Old Dec 5, 2006 | 05:26 PM
DC4 me's Avatar
Default Re: Camber kit install problem` (TunerN00b)
cool, im gonna use a hammer. thanks.
88CRXJ
13
Sep 30, 2009 09:35 PM
AdReNaLiN
Oct 17, 2008 12:00 AM
1fastvtec
Feb 6, 2006 04:47 AM
tegSB85
Suspension & Brakes
Aug 4, 2005 09:32 AM
accordfreak
Jul 13, 2003 02:09 PM
