Suspension & Brakes Theory, alignment, spring rates....
EG SWAY BAR HELP!
Old Dec 4, 2006 | 02:28 PM
Cream's Avatar
Default EG SWAY BAR HELP!
I have a jdm 23mm rear itr sway bar with asr subframe brace and was thinking about getting a gsr front sway. i think the gsr sway is a 23mm or 24mm so it should be pretty neural. i dont have a stock sway bar so my front lower control arms have no mounting holes. can i use ls front lower control arms instead of the gsr since it will probally be a little cheaper? what other parts do i need for the front besides the sway bar, endlinks, D brackets, and lower control arms?
Old Dec 4, 2006 | 03:45 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: EG SWAY BAR HELP! (Cream)
Any of the Integra front arms will work, and your list of stuff is complete
Old Dec 4, 2006 | 05:17 PM
FalkenSiR's Avatar
if you're going for a good suspension setup that will handle, then a big front sway isn't the way to go.
Old Dec 4, 2006 | 05:34 PM
Suspetise...
Default Re: EG SWAY BAR HELP! (J.MONEY)
A front bar alone will make for an understeering pig, but with the rear bar he has, the car should handle very well. I run a very similar setup (USDM ITR rear bar is the only difference) and love the balance. On track (and even moreso on the street) I don't even want a more rear-biased setup.
Old Dec 4, 2006 | 05:50 PM
BlueIntegraBoy's Avatar
You got the parts you need. I have a GSR 24mm front and ITR 22mm rear. Love it.
Old Dec 4, 2006 | 08:07 PM
Cream's Avatar
Default Re: EG SWAY BAR HELP! (BlueIntegraBoy)
okay so i picked up the gsr front lower control arms and the front gsr sway bar the bushings are in okay condition but the endlinks are broken can i get them from a acura dealership or can i use aftermarket ones? also i have some spare polyuthrane bushings laying around but they are 22mm and the gsr sway is 24mm i believe, will it fit?
Old Dec 4, 2006 | 08:54 PM
Suspetise...
You can get them from the dealer, or use aftermarket. For a stock bar, aftermarket is probably more expensive, and not really worth it. That poly bushing probably won't work, unfortunately.
Old Dec 5, 2006 | 12:43 AM
Cream's Avatar
Default Re: EG SWAY BAR HELP! (Stinkycheezmonky)
so i might as well get the oem endlinks and bushings anyone know the part #?
Old Dec 5, 2006 | 04:25 AM
My95SlvrBlt's Avatar
OEM endlinks for GSR bars are like 60 each...
I have yet to find an aftermarket substitute
Old Dec 5, 2006 | 07:26 AM
Cream's Avatar
Default Re: (My95SlvrBlt)
damn thats hella bank
Old Dec 5, 2006 | 12:03 PM
Cream's Avatar
Default Re: (Cream)
do i have to use gsr endlinks or can i use ls endlinks? 60 bucks for endlinks are
Old Dec 5, 2006 | 12:13 PM
Default Re: (Cream)
__x
I
x
Where X is the nut, I is the bolt, and the top of the I meets the underscores is a balljoint sort of joint of the GSR endlink
X
I
I
X
X is still the nut, I is threads/bushing, and the dash is the LCA.
Old Dec 5, 2006 | 07:24 PM
Cream's Avatar
hmm... i have the front sway bar, lower control arms and d brackets so i need all of these right?
51306-ST7-000 BUSH (24MM) [QTY: 2]
94050-08080 NUT, FLANGE (8MM) [QTY: 2]
95701-08016-08 BOLT, FLANGE (8X16) [QTY: 2]
51320-ST7-003 LINK, FR. STABILIZER [QTY: 2]
51312-SR3-000 RUBBER [QTY: 4]
90212-SA5-003 NUT (10MM) [QTY: 2]
90362-SF1-003 NUT, SELF-LOCK (8MM) [QTY: 2]
looked them up they come to 150$$ online probally even more if you go to a dealership. anyone know any good sites for oem acura parts?
Old Dec 5, 2006 | 07:32 PM
broketuner-Sol_Si's Avatar
Default Re: (Cream)
I thinkn energy suspension would have all those considerably cheaper
Old Dec 6, 2006 | 08:09 AM
Cream's Avatar
Default Re: (Cream)
bump
is this list complete of all the parts i need?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cream &raquo;</TD></TR><TR><TD CLASS="quote">hmm... i have the front sway bar, lower control arms and d brackets so i need all of these right?
also i called energy suspension for the endlinks since they do not have online ordering and they told me that they only sell to business' wholesale. anyone know of any other good sites?
Old Dec 6, 2006 | 08:49 AM
Default Re: (Cream)
you can get them either from summit or a local pepboys
Old Dec 6, 2006 | 01:16 PM
Cream's Avatar
Default Re: (broketuner-sol_si)
can i use these energy suspension sway bar endlinks for my 2001 gsr front sway bar?
or do i need those L shaped endlinks?
Old Dec 6, 2006 | 04:59 PM
TunerN00b's Avatar
Default Re: (Cream)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cream &raquo;</TD></TR><TR><TD CLASS="quote">can i use these energy suspension sway bar endlinks for my 2001 gsr front sway bar?
or do i need those L shaped endlinks? </TD></TR></TABLE>
Those would NOT work on my 00 GSR stock front swaybar, I can tell you that much. A 90* bend in the endlink itself is needed to connect the bar, because they are drilled for a horizontal bolt. I'm going to assume the 01 swaybar is the same, and that they won't work for you.
You can see how the endlinks differ here. Notice 18 on the left, and 6 on the right.
Old Dec 6, 2006 | 05:02 PM
Default Re: (TunerN00b)
Go to pepboys with this part # 16.8104 (70)...it's right from the ES website....
http://www.energysuspension.com/pages/acura.html
Old Dec 7, 2006 | 09:57 AM
Cream's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>hmm acually i might be able to reuse the endlinks i think i just need part # 5 on the right side. however the screw part on part #6 on the right side is bent. ill post up pics later and see if there reusable.
Old Dec 7, 2006 | 10:01 AM
I have a GSR bar WITH both endlinks good which I could sell you.
Old Dec 7, 2006 | 10:02 AM
Cream's Avatar
hmm i really have no use of 2 front sway bars but how much you lookin for it shipped to 94402?
Old Dec 7, 2006 | 10:08 AM
Cream's Avatar
Default Re: (Cream)
the gsr and type R front endlinks are the same right?
Old Dec 7, 2006 | 11:25 AM
Default Re: (Cream)
yeah, gsr and type r endlinks are the same. I cant sell it without the endlinks, because thats what is worth the money.
MattNYC
Jan 22, 2010 10:18 AM
bakomack
Aug 8, 2009 03:14 PM
civic89si666
Feb 16, 2009 05:59 PM
royalrebel
Suspension & Brakes
11
Dec 19, 2008 07:19 PM
realis9
Jun 11, 2007 11:31 PM
