water temp
Old Dec 4, 2006 | 02:21 PM
soon2bdropped's Avatar
Default water temp
okay i notice that the car gets to operating tempature.. when u turn the heat on for a good 30-45mins.. either full blast or not.. the tempature on the guage goes down to the blue line which is cold.. does it mean i need a new thermostat.. whats going on here... if u turn heat off than car tempature rises to operating temperature..
Old Dec 4, 2006 | 02:46 PM
Homesickelian's Avatar
Default Re: water temp (soon2bdropped)
yeah mine does the same. Also mine takes forever to warm up. At 35 degree and a little bit of heat on it didn't warm up in a 30 min highway drive.
Does it take a long time to warm up? If it does I might suspect the thermostat.
I haven't had the time to change mine and find out but it is an easy repair.
Also keep in mind full blast for 30 mins is sucking a lot of heat so it might not be to unusual.
I'm not sure what else could be responsible for ill heat transfer but hopefully someone else can help you.
Old Dec 4, 2006 | 03:14 PM
BLKFLSH's Avatar
Default Re: water temp (Homesickelian)
Thermostat is probably stuck open. That's better than stuck closed though (overheating).
Old Dec 4, 2006 | 06:14 PM
Default Re: water temp (BLKFLSH)
alright so i'm going to change the t stat..
Old Dec 4, 2006 | 07:41 PM
AJ06's Avatar
my car needs a good 30-45 minute drive to get close to the 1/2 temp gauge place... now that the cold set in.
Old Dec 5, 2006 | 06:39 AM
Default Re: (AJ06)
I don't know but that doesn't sound good. I mean if it doesn't heat up right doesn't that mean the oil might not be flowing properly?
Mine wasn't even heated up at the end of the 30 min drive though, it went up just a slight amount from the bottom.
Old Dec 5, 2006 | 08:59 PM
Default Re: (Homesickelian)
fixed it.. put a new thermostat from autozone.. the stat was stuck in the close position.. thanks
Turbotype
Sep 9, 2010 02:30 PM
danielblushtein
Jun 25, 2010 09:58 AM
Chuethou_b18c5
Mar 15, 2007 10:46 AM
PM-Performance
Feb 1, 2004 07:09 AM
