Oil leaking from rear strut?
had that problem with my illumina's, REPLACE, i only did one cause i was a little strapped for $, but eventually it went from leak to BLOWN!!
Damn, that sucks. Money is tight right now.
Can I ride it out for a while, or should I replace ASAP?
Front are tokico blues, rear are stock.
U can probably ride it out but your ride will continue to deteriorate until the shock has no oil left in it. Why did you install new shocks when you had springs installed?
alfaaay
Mar 31, 2003 06:21 PM
