crower stage 2 cams? are they fine for my setup?
Old Dec 4, 2006 | 01:03 PM
1sickda's Avatar
Default crower stage 2 cams? are they fine for my setup?
my setup is gonna be this
b17a1 motor block is stock and unotuched.
crower stage 2 cams,
dual valve spring and retainers, crower, skunk 2 or supertech
valve's are gonna be adjusted properly
gonna be gettin tuned on the dyno wit chrome
adjustable cam gears- toda or skunk 2's
greddy timing belt
prelude h22a jdm green top injectors
str fuel rail
jdm sir ecu
obd 0 to obd 1 harness so i can tune easier.
itr lsd tranny, lightened flywheel, stage 3 racing clutch
cat back exhaust stainless steel with high flow cat.
fuel pressure regulator
i had the jdm itr cams in my car but got bored of them they are ok but i want something a little more agressive. so will these cams be ok?
Old Dec 4, 2006 | 02:03 PM
87shytwhip's Avatar
Default Re: crower stage 2 cams? are they fine for my setup? (1sickda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sickda &raquo;</TD></TR><TR><TD CLASS="quote">my setup is gonna be this
wait so you didnt do it or your just thinking about it.. personally i wouldnt have chose a b17 block to begin with.. it kinds shows that you didnt or couldnt afford a better motor.. the add ons are above average but you also failed to mention what are your goals for your car such as N/A or FORCED INDUCTION..
i would have saved the money in the injectors and such and bought a better block to start from.. giving you more power options
Old Dec 4, 2006 | 04:20 PM
1sickda's Avatar
Default Re: crower stage 2 cams? are they fine for my setup? (87shytwhip)
well i got a good deal on the b17a1 motor. so i thought for sure it has low milage off my friends showcar. i enjoy it i bought it because around here in ontario its very rare dont see hardly any around and i thought it be something different building it instead of a newer gsr or type R. and i could afford a different motor but i wanted to stay with something different. put it this way my rims are work emotion cr, in 16;s
Old Dec 4, 2006 | 04:22 PM
1sickda's Avatar
itss a N/A setup just for little bit extra power my final goal with building block is to get close to 200 whp. well see.
Don E
Feb 28, 2010 09:21 PM
snowblind7x
Feb 20, 2006 02:34 PM
ff terror
Mar 22, 2005 11:19 PM
superturboprelude
Nov 29, 2004 06:27 PM
Pnoyej6
Sep 25, 2004 09:04 PM
