FINALLY!! GSR TRANNY
Old Dec 4, 2006 | 12:59 PM
razz9818's Avatar
Default FINALLY!! GSR TRANNY
FINALLY BROUGHT MY BABY UP TO DATE ADDED A GSR TRANNY ACTION KEFLAR
CLUTCH AND A ACTION FLYWHEEL 12LBS NOW I LAUNCH QUICK AS F*$K AND
NEED TO CHANGE GEARS ALOT QUICKER I LOVE IT!!! NOW THIS IS WHERE I
NEED SOME INPUT FORM H-T WHAT SHOULD I DO NEXT KEEP IN MIND ITS A RS
MODEL, SO, NON V-TEC THINKIN OF TURBO, BUT, SHOULD I DO MY HEAD FIRST
OR SLAPP THE TURBO ON TILL MY HEAD GOES? I GOT ABOUT 140K. THE OTHER
PART OF MY QUESTION IS..HOW CAN I PUT MY GSR TRANNY TO REAL USE DO I
NEED A GSR ECU TO REV HIGHER AND HOW CAN I PRODUCE POWER IN THE
HIGHER RPM'S..SORRY IF ITS A STUPID QUESTION BEEN OUT OF THE LOOP FOR
A LONG BROKE TIME...THANKS IN ADVANCE!!!!
Old Dec 4, 2006 | 01:31 PM
PrinceAli132's Avatar
Default Re: FINALLY!! GSR TRANNY (razz9818)
1. Turn off caps.
2. Create whole sentences, and clearly ask your questions. That was a pain to read.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by razz9818 &raquo;</TD></TR><TR><TD CLASS="quote">BUT, SHOULD I DO MY HEAD FIRST
OR SLAPP THE TURBO ON TILL MY HEAD GOES? </TD></TR></TABLE>
Why do you think your head will go? First make sure your car is in good condition, especially mechanically. If not, your going to encounter a ton of problems when boosting. Perform a compression and leak-down test. If everything checks out then I would go with a turbo setup first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by razz9818 &raquo;</TD></TR><TR><TD CLASS="quote">THE OTHER
HIGHER RPM'S</TD></TR></TABLE>
Why do you want to rev higher? Your not making more power than you were before with a tranny. Stick to the stock redline. Two things determine your redline: your valvetrain, and where you stop making power. Reving past your redline will cause you more prolbems; i.e rebuilt head, possibly even a full rebuild.
To produce power in the higher RPM, a good set of cams will help. But there are also other aspects that affect this. Do some research and you'll find all the information you need.
Ali
jay-d-em
Northeast (Sales)
11
May 24, 2008 04:02 PM
ll Del La Sol ll
Jun 10, 2005 11:37 AM
FermiumHalo
Sep 15, 2004 04:57 PM
STUCKED
Aug 22, 2004 04:37 PM
sydag5
May 10, 2004 08:38 PM
