civic cx regulator on ls motor?
Old Dec 4, 2006 | 12:58 PM
turbotime's Avatar
Default civic cx regulator on ls motor?
will a 92 cx fuel regulator work on a 92 ls motor or will it cause issues?
Old Dec 4, 2006 | 01:27 PM
turbotime's Avatar
helllppp
Old Dec 4, 2006 | 02:08 PM
EJgsr's Avatar
Default Re: (turbotime)
1.8 vs 1.5 something will be different.
it will run lean.
Old Dec 4, 2006 | 02:11 PM
my_slow_civic's Avatar
Default Re: (USDMej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">1.8 vs 1.5 something will be different.
it will run lean.</TD></TR></TABLE>
They're the same, minus bolt pattern. Both regulate the same PSI.
Old Dec 4, 2006 | 02:31 PM
EJgsr's Avatar
Default Re: (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">
They're the same, minus bolt pattern. Both regulate the same PSI.</TD></TR></TABLE>
are you 110% sure?
Old Dec 4, 2006 | 03:03 PM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">They're the same, minus bolt pattern. Both regulate the same PSI.</TD></TR></TABLE>
well they are the same bolt pattern so idk if ur right there. Anyway decided to use the ls fpr anyway.
For some reason the engine is turning over, getting spark and fuel, but not firing, any ideas? I pulled the plugs and they were majorly soaked in gas so im letting it air out for a few minutes then ima try again..
Old Dec 4, 2006 | 03:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">well they are the same bolt pattern so idk if ur right there. Anyway decided to use the ls fpr anyway.
For some reason the engine is turning over, getting spark and fuel, but not firing, any ideas? I pulled the plugs and they were majorly soaked in gas so im letting it air out for a few minutes then ima try again..</TD></TR></TABLE>
Some D series regulators have a different bolt pattern.
Check your timing.
Weak!EG
Apr 7, 2007 12:58 PM
H23 Power
Jul 10, 2006 06:49 AM
b16sellout
Dec 6, 2004 08:36 PM
Acc91ord
Apr 18, 2004 11:40 AM
bradykiller
Aug 31, 2003 10:21 AM
