Steering Wheel Creak
Old Dec 4, 2006 | 12:09 PM
Black Ack's Avatar
Default Steering Wheel Creak
Recently my car has started to make a creaking noise when I turn the steering wheel. It only seems to do it when the car is at a complete stop (engine turned on), and at very low speeds (like pulling out of a driveway). I checked the power steering fluid level, and it looks fine. It only seemed to start when the weather got colder, but that may be a coincidence. Would this indicate a need to change the power steering fluid? Could it be something else? Thanks in advance.
Old Dec 5, 2006 | 07:22 AM
markEj's Avatar
Default Re: Steering Wheel Creak (Black Ack)
i posted the same question here:
https://honda-tech.com/zerothread/1829140
does it sound anything like that?
Old Dec 5, 2006 | 09:19 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I think he's asking about a faint creaking sound (not a loud squeel), mine does the same thing. I'm thinking it could be the steering rack.
Yours is definitely a belt slipping.
Old Dec 5, 2006 | 11:20 AM
Black Ack's Avatar
Default Re: (PatrickGSR94)
I'm at work now, so I can't listen to the clip since there's no speakers on this computer. It's not a real loud noise, just kind of a rubbing/squeaking noise when I turn the steering wheel. Is the steering rack something that I might be able to adjust/fix myself? Thanks for the input guys.
Old Dec 6, 2006 | 12:48 PM
zeroroot's Avatar
I was also wondering about this, I have a 93 integra LS and it makes a rubbing noise when I turn the wheel, nothing like that loud squealing posted in the video clip.
Old Dec 6, 2006 | 01:42 PM
gsrclan's Avatar
Default Re: (zeroroot)
My 97 gsr make the similar noise. It's not the belt or fluid because I replaced them both.
Old Dec 6, 2006 | 01:44 PM
gsrclan's Avatar
Default Re: (gsrclan)
Also I can feel some faint vibration from the steering wheel when it does this, almost like it needs some lubrication somewhere in the steering column.
Old Dec 6, 2006 | 02:14 PM
zeroroot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex-SI &raquo;</TD></TR><TR><TD CLASS="quote">
This thread is old as shat , BUT , I thought i could shine some light on the problem.
My Rex did the same thing , I took off the steering wheel and found the cause , the metal tabs for the horn that ride on a round plate like a track when the wheel turns was scratching due to no more lube on it. Easy fix , just a small dab of lithium grease and rubbed it around the horn disc.
Hope this helps someone since this thread is old. </TD></TR></TABLE>
After about half an hour of searching I found this post and I'm pretty sure this is what my problem is.
Old Dec 6, 2006 | 03:36 PM
crx_88_si's Avatar
https://honda-tech.com/zerothread/1830285
i replied in that thread, sounds like the same problem.
noahs_ark
Honda Civic (2006 - 2015)
Sep 12, 2016 05:25 PM
transitions
Oct 4, 2011 06:43 PM
avargas28
Jan 12, 2009 09:09 AM
CWBETB
Mar 27, 2008 03:08 PM
RuskeR
Oct 30, 2002 05:59 PM
