Oil Feed/Gauge setup - Questions inside.
As it stands right now I my turbo fed from the back of the block where the stock sensor is.
I want to use the same feed to go to a tee, as I would like to hook up my new autometer oil pressure gauge, the stock 'no oil pressure' sensor, and the feed to my turbo. Since only one of these actually uses oil, will there be enough oil from the feed on the back of the block?
Here's an example of what I want to do:
(Sorry ahead of time if I stole your picture. I copied the link while I was searching through 32149 threads and forgot to write down who the pic belonged to. May belong to speedlabx2005.)
mine looks the same
haha
mine is alittle bit more work but i think this is better than the pic u posted
i used a tunertoys block fitting
that comes up to the T
and the stock sensor goes into the block fitting
haha
vladd
Jun 26, 2006 07:18 AM
